99 Civic Si help
99 Civic Si help
I recently bought a 99 EM1. The car runs and is in decent condition, but burns oil badly and smokes a bit at higher RPM's. I think it's an issue with the rings or ring lands. That being said, I'm looking for it to be a reliable DD, with the possibility of modding it in the future. So, I'm guessing the safest route would be to replace the motor. It's the original B16A2 with 150K miles on it.
I have never attempted a motor swap, I've really only done very basic maintenance, but I'm hoping with all the guides online and help of a buddy or two, I can get things done.
With my lack of knowledge on swaps and mechanics, I'm looking for the easiest swap possible. I know the car is OBD2b. Is it possible to swap another B16A2 in and be a direct fit? I don't see the B16A2 on HMO?
Would this longblock be a direct swap in, plug and play basically?
http://www.hmotorsonline.com/shop/sc...age&item=30025
I don't understand, would I need to convert to OBD1?
Re: 99 Civic Si help
you must remember you're going to be putting a motor in that no one really knows the condition of.
that being said, you'll have to swap over your injectors and distributor if using obd1 motor. with jdm engines and usdm obd2 ecu, you'll have to do the ckf rewire.
There are plenty of OBD2 b16s out there. The reason you are not seeing a b16a2 is because you are looking at motors from Japan. The 5th digit is the region that the engine is from. If you stick with OBD2 it will be plug and play. Engines from Japan dont have emissions so you can use your harness off the engine you pull out.
This is a link to a engine from JDM Engine Corp for a OBD2 b16
http://www.jdmenginescorp.com/engine...tor-long-block
I like to party
OP have you looked into building an LS/VTEC? For far less money than you would pay for a new B16 motor you can put a 1.8/2 liter bottom end on there with an 89mm crank and make FAR more torque and power. The car will be soooo much nicer to drive with more displacement, trust me, I've owned 3 EM1s, the extra torque really wakes up the car.
An LS block with B16 pistons, and stock LS rods and crank, simply bolted onto your stock B16 head, will make almost 200hp. (at the crank)
You can also use a B20 block with the 84mm RS machine 'itr style' pistons on ebay for cheap and make H22 power and torque.
This is probably a good opportunity to upgrade the motor seeing as how it needs attention anyway.
Location: Rancho Bernardo, San Diego - Work in Anaheim Hills
2LEM1, great idea sounds like a frankenstein. Also, what would you suggest to be the most conservative, reliable, and yet useful power set up?
I like to party
For the most reliable LS/VTEC while retaining the cheapest cost, I would run B16 pistons on LS rods on the LS crank. The B20 will make more power, but you will need aftermarket pistons. The LS you can reuse your B16s and it will put you right around 12:1 compression if I remember correctly. That's a bit on the high side, but it's perfectly streetable with a good tune, and it will also take great advantage of some decent cams.
For a cheap build I would have the LS block honed but leave it at 81mm. Reuse your B16 pistons. They will fit right onto the LS rods on the 89MM crank. Bolt that up to your B16 head and I will guarantee you make more power than a stock GSR, for under $1000
Add some good cams and a header and that setup is capable of 220+ whp
Depending on your goals and what you're really after I'd look past what 2lem1 is suggesting. Also, depending on your budget.
My advice was a method to save money. You can find a short block in the 1-200 dollar range. B16 blocks = nobody really wants them so they sell cheap. I've also had Ls vtec and it is fairly easy but its not beginner easy and you'll end up paying a decent amount in labor fees to get the bottom end prepped and assembled.
Does HMotors sell OBD2 long blocks?
OBD won't matter since you have a complete motor from your car and you can swap literally everything over.
I'd look locally for a short block. Try craigslist or your regional HT classified section. YOu can use any variation of a b16 motor but the b16a2 is what belongs in your car and will be the newest. PM me if you have any specific questions.
https://honda-tech.com/forums/hybrid-engine-swaps-18/obd1-b16-into-1999-obd2-b16-civic-si-1308853/
So basically this link is saying it doesn't matter if I get an OBD1 block because I can swap over the missing components from my OBD2 B16a2.
Am I understanding correctly?
If you loved me, you'd all sell me your magic cards to me today
https://honda-tech.com/forums/showthread.php?t=1308853
Florida. I'm rustling the **** out of my own jimmies though. Frustrated because I feel like I don't understand still. I'd rather buy a short/long block from HMO or another reliable shop, but all I see is OBD1? 96-98 (SiR-II) Long Block
Been searching classifieds for B16 short block but mostly see GSR.
Maybe someone could PM me and help. I feel like a complete idiot.
You are rustling your own jimmies. It's a really basic job. It's been awhile since I've messed with 99-00 si but if I remember correctly, the only difference in the bottom end is crank position sensor and knock sensor. You can grab both those off your motor. The head will completely swap over and you'll use EVERYTHING else off your motor
I have a b16a2 short block I can sell you for 400 shipped. It's in good running shape so with my block the only thing you'll need to replace is head studs and head gasket. I've reused both before but not everyone recommends it.
