99 civic overheating
Hey guys I got a 99 civic with a turboed b18b1 i believe(the ls non vtec one). Just normal driving around town it overheats. I have flushed out the radiator to make sure it not clogged and removed the thermostat to make sure the water pump is working. The fan does kick on and the coolant in the car is new. So looking for some advice on other places to look. And o ya I dont have the heater core hooked up just a bypass hose from the in to out on the engine. Any help would be greatful.
Re: 99 civic overheating
Quite a few people seem to be running into this issue lately. Try swapping out the fan switch. Since you have taken care of everything else this is one of the last things to check minus the headgasket as stated above. Mine was doing the same thing and flushed the system and swapped thermo and switch and shes good as new.
Um honestly i dont know, Rad i know isnt stock but there are no markings on it so i bet its an el cheapo and i plan on replacing it as soon as i can and the fan looks like the stock one.
kyden
as far as the reservior goes it fill up a little bit but doesnt over flow.
guessohw ill check on that switch, more in likely ill just buy a new one if there not really expensive.
kyden
and guys any advice on a good radiator to get. I know im gonna replace the one in here anyways so just trying to get a feel for decent ones.
Also picked up a oem thermostat and fan switch, and installing them tomorrow.
KayGrier
34
06-02-2015 09:08 PM
redlinetuning
22
01-04-2012 06:57 AM
beastman@
17
07-05-2009 12:55 PM
