99 Civic - Dorman 673-439 Exhaust Manifold? Heat shields Required? Torque for nuts?
#53
#54
#55
Re: 99 Civic OEM Exhaust Manifold - Covers Required?
Ohm test the heater element of the secondary O2 sensor (part #9 in post #12).
#56
#57
Re: 99 Civic - Dorman 673-439 Exhaust Manifold? Heat shields Required? Torque for nu
Sorry, I mean nuts. Here is a photo. I don't have anything to compare this against, but I suppose they are not as rusty as they get...
What's a good way to get to the lower second one from the right? Not a lot of space to maneuver down there.
#58
#59
Yes, I was referring to socket and ratchet. I'll try with a box wrench.
So as long as the studs don't break or strip, I should just leave them in there?
I don't have to worry about the studs' torque if all I am doing is removing the nuts?
#60
#62
Do you know if the entire unit can be pulled out from the top or would I have to do it from under the car?
#63
top
Remove O2 sensors (also soaked in PB Blaster); don't damage wires or connectors and clean oil from wires when removed.
Remove exhaust nuts
Replace gaskets
Remove exhaust nuts
Replace gaskets
#64
I was concerned about the manifold / catalytic converter not clearing the AC pipes.
#65
#66
Hi for what it is worth, I replaced my manifold / cat on my 1997 LX Sedan, and I unbolted the old manifold / cat, used the included gasket, and didn't remove the studs.
I just bolted the new one on and used the torque specs from the book. It is a little bit of a pain finding the right combination of socket extensions and / or sockets to get at all the nuts when installing, but not the end of the world.
I reused my O2 sensor, after soaking it in vinegar then blowing it out.
The code I had was from the leaky exhaust manifold, so my old O2 was ok.
Passed smog no problem...
As far as rusty bolts, if you can take a brass brush and some WD-40 and scrub them up so a nut can go on smoothly, great. If they are so rusty they don't function or their integrity is degraded, replace.
I'm in California also, so I feel your pain on the cost of a cat around here!
One more thing, it has been a few months, but when I removed my old manifold, I was able to sqeeze it out once all the bolts were removed. I didn't have to take out a bunch of other stuff.
#67
Seagull Management
Those nuts aren't really that rusty, they should come off easily enough. They aren't the proper nuts though. The original nuts had 6 cuts in them. IIRC the replacement nuts don't have the cuts, but they also don't look like the ones pictured either.
#68
How important is the torque on the bolts that connect the cat to the exhaust pipe?
Should I be as careful about those as I am about the manifold nuts?
#69
Do you suggest using new nuts?
#70
#71
#72
#73
Thats why splurging for cert return receipt postage may be worth it... along with copies of the envelope and contents....
#75
