99-00 si cluster in a eg?
hey everyone, i just got 99-00 si civic cluster, i need help real bad...... need picutres of one done in a hatchback 92-95 or diagrams etc......and what does it take to do this conversion? THANKS ALOT.
Re: 99-00 si cluster in a eg? (Slammed Si)
I DID THIS SEARCH...why else would i put it up.......search ur self u don't know what your talking about~~
jus f0 dekarayshunZ
Re: 99-00 si cluster in a eg? (Civicr2gs5)
best i could do https://honda-tech.com/zerothread?id=96954
dang still nobody know or have a picture of it done......come on people!! i need help!!
jus f0 dekarayshunZ
found this also....You can make the Si gauage cluster work, it can be a pita though. I have a 2000si gauage cluster wired up in my 93. You need to either get the whole wiring harness or just the plugs (hopefully with at least some wire connected to each. Unfortunately I didn't document any of the wiring I did, but this is how I figured it out. If you look at the back of each gauge cluster you can figure out where each wire goes and thus what it is responsible for, just follow the leads where each wire connects to, label that wire whatever it is on your stock wires, then cut your stock connectors off, get the connectors with the wires from si. label where each wire goes to from each lead, then connect the proper wires from the si connectors to your stock wiring harness. plug it in, and you have the wiring done. It took me about 45 mins to do this when I figured out what to do. I think the hardest part to figure out was the turn signals.
No physically it won't fit in. I swapped in an entire dash from a totalled si. (I am about to take it out, never did fit a well as I wanted.) I am about to put my stock dash back in but plan on keeping my cluster, actually switching to an ex cluster, the redline throws me off when I drive hard, tend to shift too late. But it's the same thing basically, so I'll see what I can do, I should be doing this in about two weeks.
btw...i searched
btw...i searched
Re: 99-00 si cluster in a eg? (ciRcuitSi y0!)
wow nice......do you have any pictures? but do you think ther'es a way you can put it in da dash wit da 93 civic hath dash or do i have to FULLY swap the 99-00 si Dash in??
Help we my pennies
Re: 99-00 si cluster in a eg? (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR »</TD></TR><TR><TD CLASS="quote">i like my gsr cluster just FINE</TD></TR></TABLE> isa grs and si clust the same?
Radyjr
01-20-2005 05:57 PM
