98 civic strut problem
hi, im new into imports. I fell in love with the hatches and had to have one. i am currently settling with a 98 civic coupe ex. it came with the d16y7 motor =[ no vtec. im going to do a mini me swap shortly though.
but first i need to fix something.
the person that had before me heated the springs to lower. it was okay at first but its now making noises and eating the tires. i was wondering if i could put stock 94 civic coupe struts on it with no problem.
thanks guys.
bobo =]
thanks guys.
bobo =]
Resident Gearhead
Re: 98 civic strut problem
Not too sure about the rears, run a search and see what comes up, or maybe someone else knows.
yeh, the fronts fine atm. i am trying to find some cheap aftermarket ones or stock ones. doesnt matter to me atm.
thanks, still looking for back stuff
yes, it should have, it also should have came with ac lol... but yes, they but in the d16y7.... im thinking of doing a mini me swap or going straight for a b18c1. im not sure yet.
money actually depends on this.
im getting my system (12 inch earthquake sub, and my 2 15' subs atm) getting the box built.
but i am currently tryn to fix my suspension...
any tips or thoughts
thanks
thanks
well ur problem is the springs not the struts so that wouldnt do anything. i would just go buy aftermarket good suspension unless you want to go back to the stock look. its eating ur tires because your out of alignment fix it and then go get the toe adjusted
well when they dropped the car, it collapsed the seals in the struts... should i just get some stock springs and go from there? would springs from a 94 civic coupe fit? i basically got a 94 civic parts car for the d16 mini me swap.
thanks guys.
bobo
thanks guys.
bobo
Yes, I've used '92-'95 front struts on my '96. There are 3 tabs you may need to grind off (I had to) to get them to fit through the mount hole. Very easy to do, I just zinged them off with a Dremel.
Your correct on the front, i had to also while putting eg shocks in my friends 97
The rears will fit, however the shock fork is wider then the lca bushing, so either get spacers or bend the shock fork.
OP- the reason why your eating tires, is not due to your shocks, well, the shocks arent responsible for all of it. Your alignment is off, and the toe is killing your tires.
so i should onlyhave to replace my springs right?
they did it like this to completely lower it.
a cheap way. but it only eats the tires on the back. lol.
but... i think im getting some springs shortly.like this week sometime
any more thoughts ill be thankful for.
ok, i bought a full coilover kit to fit my civic.
will be putting on shortly ( next 2-3 days).
this will tell me if i need new struts and what not.
getting alligned saturday as well.
thanks guys =]
bobo
thanks guys =]
bobo
UndergroundTuning
01-29-2010 01:10 PM
Crippledduck51
01-05-2007 10:19 PM
Knightmare69
Audio / Security / Video
08-04-2004 06:19 AM
