98 civic dx hatch - idle is surging
I have a 98 civic dx hatch and my idle is surging on start up and when its warmed up. I had this problem over the summer as well and replaced the iacv and it seemed to run fine but i recently took off my intake manifold to replace a broken bolt and the surging came back. I have no clue what to look for now please help.!
Re: 98 civic dx hatch - idle is surging
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
so i checked the pcv valve , didnt seem bad but i bought a new 1 and replaced it anyways and my idle is still surging. anyone else have tips pleaseeee!!!
PCV doesn't have anything to do with it unless the hose that's going to PCV is damaged or leaking.
i jst finished working on it and everything seems to be right we can't find the leak. i tried spraying carb spray around all hoses that go to the intake manifold and the idle didnt change at all. i also replaced my tb gasket along with the intake manifold
When the idle is surging, remove the air intake system and then use your finger to cover the port/hole inside the throttle body leading to the IACV. Does covering the hole stop the surging and lower the idle speed?
civichb98
38
10-01-2011 09:12 PM
