98 civic auto transmission prolbems help please!!!
Well i am in need of advice/help. I did a search but it did not fullfill me. Anyways, I put the car on jackstands on the front and the driver side. I shift the car in different gears just to see if the axle was working propery because the right side was not spinning at all. Then, it grinds like kkkkkerrrrrrrrrrrrrrrrrrrrrrr. but before driving. the car is drives normal.
Also, before the car the rolls back in park. THIS IS WERID.
one more question what is the different between dexron III and honda ATF. my mechanic recommend honda ATF?
any ideas?
any ideas?
Re: 98 civic auto transmission prolbems help please!!! (exx07a0b)
lol, I like the sound effect!
First check trans fluid level. Then check to make sure that the shifter is changing gears on the trans, look for the lever moving on the trans when you shift. If it is moving and your car still will not drive then its likley a mechanical problem. I recommend taking it to get it fixed.
also if it rolls back in park then the parking pawl is not engaging.... did you slam it into park while the car was still moving?
Re: 98 civic auto transmission prolbems help please!!! (FJmbztech)
ahhahah lol, we were not in the car when the car was moving back but the window was down . my buddy pulled the emergency brake. I just don't know what to do. I think it might be a transmission problem. Thanks though! I'll trying looking at the lever shifter.
matcauthon19
06-07-2014 02:58 PM
