97 sedan power locks do not work
Old 12-15-2010, 07:24 AM
bub
bub's Avatar
Default 97 sedan power locks do not work
i just bought a 97 civic sedan a few weeks ago and it has power locks but the power lock switch doesn't do anything. there is only one and its on the driver's door. do you think the switch went bad? anything i should test to see? where should i get a new switch from? thanks.
Old 12-15-2010, 10:32 AM
Former User's Avatar
Default Re: 97 sedan power locks do not work
Is 20A hood fuse 51 blown?
Old 01-09-2011, 09:51 AM
bub
bub's Avatar
replaced the switch and still nothing. i checked the fuses and they are good. i took off the door panel and noticed there is a power lock control in there. i have power going into the control box but no power going to the switch. do you think it is the power lock control box?
Old 01-09-2011, 10:01 AM
Old 01-09-2011, 11:15 AM
bub
bub's Avatar
can i do these tests with a test light?
Old 01-09-2011, 11:29 AM
You can only easily do the voltage tests with the test light. You need a multimeter for the continuity tests. Note that some tests require neither, just a jumper wire.
fv8s
11-08-2010 04:39 PM
mach0
09-25-2007 10:33 AM
arowana23
07-18-2007 02:04 PM
-[95cxhatch]-
01-09-2004 10:22 AM
sidewayz
01-13-2003 03:25 PM
Quick Reply: 97 sedan power locks do not work
