97 Civic/Ls swap -- no click prime or spark
I have a 97 hatch put a 94 Ls in it, obd2 Ecu obd2 distributor, everything's hooked up, lights everything works, cranks and was almost starting up with starter fluid but the fuel pump isn't priming check engine isn't coming on, changed the main relay and same thing. Now we're not getting spark or fuel anyone no what this could be? We're lost been working on it for 5 days..
Re: Ek Ls swap no click prime or spark
did you check the ecu? or you might be missing a ground run a wire from the valve cover to the chassis if you havent already done so. Hope this helps good luck!
Alright I have them and still nothing. This makes no sense, it was starting on starting fluid but now it has no spark or fuel, the fuel pump won't prime, I'm putting another one in today see if that helps
97 Civic fuel pump not working
97 civic, i turn the key and the pump doesnt prime and car wont start but it cranks. i put a main relay in that was working from my integra and it wont work still. I jumped the prongs on the clip for the relay and the fuel pump runs. plug the relay back in and nothing.. any ideas?
I feel like I should be running obd1 computer? I have an obd1 distributor, obd1 alternator, obd1 injectors, and obd2 computer. I'm gonna get a step down and obd1 Ecu so I don't have to worry about running with no crank sensor
Get the OBD1 computer with the OBD2 to OBD1 ECU jumper harness. I know my spare OBD2 LS ECU has an ignition lockout that you need to bypass to get the car to start. That could be the problem.
Re: no fuel pump not working
Related threads merged.
Have you sanded and tightened the G101 ground on the thermostat housing?
What main relay terminal (terminal 5 from fuse 13 or terminal 7 from fuse 44) did you jump to make the fuel pump run?
Re: 97 Civic/Ls swap -- no click prime or spark
the green plugs that are near your ecu did you hook them back up i ran into the same promble when i did my swap and forgot to hook the green pug up near the ecu and it did not prime and would not start i hooked it up and the car ran just fine hope this helps
is that the little wire that comes out of the harness right next to the fuel rail to the thermostat housing?
1) Jump terminal 5 (also Yel/Grn wire) to terminal 4 (Yel/Grn wire) with the key in ON(II).
2) Jump terminal 7 (Wht/Blk wire) to terminal 4 (Yel/Grn wire) with the key off.
The fuel pump should run for both tests.
Fuel pump primes when jumped, just put a brand new relay in today, all fuses are good, tested all the grounds with a test light and the ground from harness to thermostat wasn't grounding, took it off and sanded it now it's grounding and still no prime or spark, and yes the green plugs are plugged in
ground your main relay directly off the relay not through the harness. I had a similar problem and when I grounded the main relay directly I got fuel and spark.
