97 Civic - cluster / gauge lights not working
Old 05-03-2015, 02:45 PM
ArtyTheKid's Avatar
Default 97 Civic - cluster / gauge lights not working
whats up ht? ive had this problem for a few months now and i really wana fix it. one night i got in my 97 civic ex (stock) and my cluster / guage lights werent on. my signal lights light up bright, srs light, cel, hazards, all my climate control lights light up, my radio, just not the backlights / guages to my cluster. ive googled and came up with a few options:
1. check fuses under hood / under dash. I did that, with a multimeter and all fuses were good.
2. check dimmer switch. as far as checking it im not sure exactly how to do that but i swapped mine out for one that i got from my local junkyard, and still no lights.
3. try changing out the bulbs. i did that, took a bunch of bulbs out of a cluster in the junkyard. not one of them lights up.
what should i do next? it sucks shineing my phone at my cluster at night to see how much gas i have lol
Old 05-03-2015, 02:49 PM
Former User's Avatar
Default re: 97 Civic - cluster / gauge lights not working
Dust off the multimeter and test whether the two cluster connector pins for the backlights have power and ground.
Old 05-03-2015, 06:44 PM
chrysler kid's Avatar
Default Re: 97 Civic - cluster / gauge lights not working
Bypass the dimmer switch, see if that works. I'm willing to bet the junkyard one is broken too
I didn't bother to try and replace my dimmer switch because I figured even a used quality ebay piece would fail again and the part is $80 new
Old 05-03-2015, 06:48 PM
This idea is inconsistent with the fact that the OP says the climate control lights work, unless I misunderstood.
Old 05-04-2015, 02:13 AM
Oops I missed that. I think this is only the third thread this week about the exact same issue so I'm getting rusty
It was a dark dark drive when my switch was out.
Old 05-05-2015, 01:15 PM
ArtyTheKid's Avatar
gona do that and ill get back to you
Old 05-09-2015, 12:18 PM
ArtyTheKid's Avatar
I have neither power or ground going to the 2-pin connector.
Old 05-09-2015, 12:23 PM
Which 2-pin connectors are you talking about?
Old 05-11-2015, 01:23 PM
ArtyTheKid's Avatar
heres a picture of the back of my cluster
http://s18.postimg.org/yyv2ihkdl/image.jpg
exactly what 2 wires should i be checking for ground and power?
Old 05-11-2015, 01:55 PM
A Google search will yield a service manual for your car.
Connector C, pins C12 and C13.
C13 should have battery voltage.
Old 05-11-2015, 07:50 PM
That loom looks completely tangled I wouldn't be surprised if the connector spade was slightly pulled out of socket
sol-oto
06-17-2018 08:56 AM
TeeKayy
07-19-2016 11:08 AM
dadrought6
11-28-2010 04:10 PM
honda011
11
08-31-2005 07:14 PM
Quick Reply: 97 Civic - cluster / gauge lights not working
