97 b18c swap.
Re: 97 b18c swap. (babiebottle96)
why dont you go with H22 if you want to drag race?
i dont know about the 1/4 time of 18C.. but its a fast enough track car.. imo
With numerous companies offering custom mount & axle kits so readily available nowadays, the H22 isn't as hard a swap as it used to be...but that stuff adds up $$$
Definitely faster than a GSR though, 30 more of both hp & torque...
Re: (loketran)
ahhh, i c, well tahts fast enough, how much did the swap cost you all said and done. i am gonna pick up the motor for about 3200, after that how much more do you think?
Re: (babiebottle96)
other than the complete swap..
you still have to get new clutch, timing belt.. and some other little stuff.. and also labor if you are not doing it yourself..
so i say probably around 1k.. maybe more
Well, depends also on how many miles the swap has on it...you may not need to do the t-belt and clutch for a while, although if you can afford it that might be a security measure...make sure it works before installing it all, otherwise it's tough to do once in the car.
Re: (klungemonger)
it is almost a standard procedure to replace the clutch and timing belt when doing the swap.. its is much easier and cheaper to do it while the engine is outside the car
True, a stock clutch is about $100 and with the engine on the ground can be done in 30 minutes or so. Getting a crank pulley bolt off isn't easy anytime though!
mynameizstitch
12
08-03-2009 08:26 PM
menacehect
Honda Civic (2001 - 2005)
11-02-2008 08:56 PM
