96 itr suspension impotant question
anyone know what kinda of front brake caliper braket i can use for the 96 itr suspension, cause noone sells it alone i would have to buy the whole suspension swap again
thanks, kyle
thanks, kyle
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">A bracket of a 92-00 civic ex/abs si, em1, or any integra SHOULD work, since the itr caliper fits on those knuckles</TD></TR></TABLE>
this is write. the calipers off the 96 ITR fronts are the same as USDM GSR and 99-00 Si.. the knuckle is the same also between the mention cars in the quote. sooo... use GSR or 99-00 Si and its a sure fit.
Re: (ej0513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 »</TD></TR><TR><TD CLASS="quote">
this is write. the calipers off the 96 ITR fronts are the same as USDM GSR and 99-00 Si.. the knuckle is the same also between the mention cars in the quote. sooo... use GSR or 99-00 Si and its a sure fit.</TD></TR></TABLE>
dont mean to jack this thread, would it be possible then to use one of those brackets on a 99ex because i believe that the si and ex are the same size rotors?
it depends on whether or not you have the 10" or 9" rotor.
If you have the 10", you need all but the rotor.
If you have the 9", you need all that AND a knuckle off what I listed.
smooth95
04-06-2006 07:48 PM
