96 HB - Power Door Locks not Working
I have a 1996 civic hatchback DX with 99 SI doors. Everything is connected using 96 floor and door harnesses. I also have the power lock control unit connected ( blue box). Everything else works fine, but how come the power locks doesnt work?
Re: 96 HB - Power Door Locks not Working
it is a tech forum, but when you get everything together, and you're so excited to try things out.. you seem to forget about those tiny blade fuses which could cause such a headache.
that does not necessarily make it a dumb question. simple problems that sometimes just require a different point of view are just as noteworthy as an engine swap. tech is tech. no need to bash on the dude because he may have overlooked something.
you called his question dumb. i'd say you're bashing. in any case, nice diagram. my power door lock on the driver's side doesn't work either. although, it only doesnt lock when the door is open. point is, i'd like to read more about this thread and if the OP gets it fixed.
I called my question dumb.. not his. If you are really adamant about figuring out your problem I have the entire 96-00 Shop manual in PDF form, if you're interested and have AIM I can send it along(only about 70MB)
I tried manually powering the power lock switch from the battery and it doesn't work. Any other solutions?
Highlights :
1996 Civic Hatchback DX
99 SI Doors
96-98 Floor and Door Harnesses
Highlights :
99 SI Doors
What did you find out with this? I'm having the same problem. I have power from fuse under hood to control module in driver door, still not working.?.
J.HA
05-22-2010 06:37 AM
honda010
03-23-2007 08:01 PM
