96 ek ebrake removal help
hey i have a complete ebrake that i want to swap into my 96 ek but idk how to remove my old e brake....its not the handle, but the entire e brake i want to replace....any help with be very helpfull thank you
Re: 96 ek ebrake removal help
x2
And you gotta remove the arm rest column. And if i remember on my Ej there were 2 bolts holding it down and a ebrake light switch connector and you gotta remove the cable from the handle. then go to the rear wheel depending on what kind of brakes you have im assuming its Drum. you gotta dissemble the whole drum set up to remove the cable.
But that's what i remember from my Ej. Please correct or add info if I'm wrong.
well im doing an interior swap from light to dark grey so i just want to change the handle..do u hav to be on flat ground to just swap the handle or something?
93civicsedan
07-07-2016 12:17 AM
xXSilentScreamXx
08-03-2007 04:44 PM
