96 del sol reverse lights not working
1996 del sol si manual transmission
OK so my reverse lights just one day stopped working they used to work fine
the sensor has 12v going to it the fuse under the dash has power as well as the socket.
However once I get to the tail light harness plug there is no power on what
is the reverse Light wires. all other lights work fine including the tag lights.
Is there another piece to these reverse lights that are required for them to
work?
work?
Re: 96 del sol reverse lights not working
Remove the connector from the backup light switch (on transmission case) and jumper the yellow wire to the green/black wire. Turn ignition switch to run. If lights come on the switch is bad.
justicap
08-08-2016 03:28 PM
dwnthehatch
17
03-12-2010 02:34 PM
redline870
07-05-2009 10:24 AM
MemphisChick625
10-03-2007 07:40 PM
