96 civic coupe a/c question
A/c system works intermittantly. Shuts off at will. Inconsistant operation.
Seems like I can get the system to cycle on if I wiggle/twist the a/c thermostat connector at the evaporator box, behind the glove compartment. Connector seems ok, but suspect, after a lot of other tests,
that the ac thermostat itself is bad. Just to verify, there three wires leading to this component, blk/yel, blu/red, and yel/wht. Can someone give me the voltages of each of these, and can this component be bypassed or "jumped around" temporarily to determine if this is the cause of the intermittant?
Other diagnostics have led me to this point, and the rest of the system checks out. any information is much appreciated.....
edit: Sometimes the a/c will not turn on at all.......then at next startup after sitting, it magically works.
Sometimes it works the whole trip, sometimes not. Never have meter handy when it quits. When the system DOES fire up, it operates normally, inc. condenser fan and normal compressor clutch operation
Once it quits, it seems to ONLY respond to the "wiggle" test at the thermostat, and operation can't be maintaned as soon as I let go of the plug.
Re: 96 civic coupe a/c question
When the A/C won't work, if you unplug the A/C thermostat and jump the Blu/Wht wire terminal to the Blu/Red wire terminal in the connector, does the A/C now work as long as the wires are jumped?
Thank you sir........I have not yet tried that, but the test you're suggesting
is exactly what I was hoping for. Just didn't know which wires to jumper.
I will post my results as soon as possible. Please stand by, and again, THANKS....
Thanks for the assistance so far....Standing by......
Probably answered my own question already, but thought I'd post the result.
Haven't had any more issues when bypassing a/c thermostat, other than the air
blowing out the vents is frosty. No doubt because the compressor runs non stop.
Guess I better plan on an r/r of the evap housing and replace the a/c thermostat
to restore proper system operation.
In the meantime, you could install a toggle switch between the 2 jumped wires. Then you can accelerate, brake, clutch, and toggle while driving.
crewchief437
Honda Civic (2006 - 2015)
02-26-2018 04:36 PM
Barrett272
07-22-2015 04:34 PM
jjrek9
07-31-2012 07:00 PM
tronic
06-02-2010 05:27 AM
My95SlvrBlt
08-08-2006 04:53 AM
