96-00 Civic Scarebird brake conversion write up.
Old Feb 18, 2009 | 09:42 PM
  #76
cracker1252's Avatar
Default Re: 96-00 Civic Scarebird brake conversion write up.
FYI.....
http://www.scarebird.com/index.php?id=22
Old Feb 18, 2009 | 09:55 PM
  #77
kgibson16's Avatar
cool write up and great beer. belgian for the win!
Old Feb 23, 2009 | 04:32 PM
  #78
jmoney45's Avatar
so does 1990 da rear disc setup fit on 96-2000 civics?
Old Feb 24, 2009 | 10:16 PM
  #79
talkJDM's Avatar
Very, very nice write up, I didnt even know this existed. I might just do this instead of going with a Complete Rear Disc Swap from a 99-00 Civic Si.
Now, I read the whole thread, but I wanted to get some assurance so I know I buy the right things from the get go if I decide to go this route. The Swap will be done on my 1997 Honda Civic CX Hatchback, so this is the parts list I need, correct?
- Scarebird "CIV" Bracket
- 99-00 Civic Si (or 95-01 Integra) Rear Calipers
- 99-00 Civic Si (or 97-01 Integra) Rear Rotors
- 99-00 Civic Si (or 98-01 Integra) Rear Brake Pads
- 99-00 Civic Si Master Cylinder
- 99-00 Civic Si eBrake Cables
- 99-00 Civic Si (or 96-01 Integra) Rear Brake Hoses & Brackets
- New Spindle Nut
I got the above info by comparing OEM Honda/Acura Part Numbers, so that's how I got those specific years - although I'm pretty sure I can use any 9.4" Rotor and any 7CLP13S Caliper and corresponding Brake Pad (right?). Anyways, Is there anything else I am missing on the list?
Oh and I will be able to use my current Proportioning Valve and my Brake Booster since they are the same as the 99-00 Civic Si (according to OEM Honda Part Numbers) due to my Car being a 1997 Honda Civic CX Hatchback.
Well looking forward to a reply, thanks in advanced!
- Danny
Old May 29, 2009 | 07:42 AM
  #80
zx12ryder's Avatar
Default Re: 96-00 Civic Scarebird brake conversion write up. (evilhonda)
Originally Posted by CerealWars
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evilhonda &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>How many doors is your Dx? If I remember right the 2/3 door share the same prop valve/brake booster as the Si, but not the master cylinder. The 4 door does not have the correct prop valve or master cylinder as the Si, but the brake booster is correct. Hope that helps, if not check out slhondaparts.com to cross reference the part numbers for yourself. As for your other question (do you use the same hub? and if so how did you secure the rotor to the hub?). Yes, reuse the stock hub. The rotor will be held in place by the caliper and wheel.
this is good information i have a 2000LX and if the above info is correct i now know what i have to get in addition to the brackets,calipers,pads, and e-brake cable.
Old May 29, 2009 | 12:04 PM
  #81
Allurian's Avatar
The only items needed for this swap are:
scarebird bracket
rear rotors from 92-95 Civic Ex/Si..94-01 Integra...99/00 Civic Si
calipers
pads
e-brake cables from 92-95 Civic Ex/Si..94-01 Integra...99/00 Civic Si
rear brake lines from 92-95 Civic Ex/Si..94-01 Integra...99/00 Civic Si
A new master cylinder/booster and prop valve is NOT needed to do a rear disc swap. This has been gone over many times. 92-95 Civic Ex/Si come with 3030 prop valve so 4040 is not needed...and Master/Booster is identical to non 92-95 Ex/Si civics
Old Jun 24, 2009 | 08:59 PM
  #82
dhoff024's Avatar
nice post very nice and detailed this really helps I just bought a 97 civic and im going to do this asap.
Old Jun 26, 2009 | 09:54 AM
  #83
ESmooth's Avatar
Just got my parts in, looking forward to doing the swap. I am glad this DIY was posted though since there are no instructions included with the kit.
Old Jun 26, 2009 | 10:07 AM
  #84
vtechjunkie's Avatar
Nice! Now I won't be such a stickler on a full disc car, and I can save money there on the next project. I'll just do this conversion.
Old Jul 1, 2016 | 05:54 PM
  #85
HondaTechMan121's Avatar
does this work for a 95 honda civic Ex 2door? what else do i need to buy?
Old Jul 3, 2016 | 04:44 AM
  #86
bump the guys site says it will work with 92-95 civics has anyone tested this?
Old Nov 12, 2017 | 07:54 PM
  #87
NickRN81's Avatar
Default Re: (CerealWars)
Originally Posted by BrakeExpert
Not to threadjack, but if anyone wants a pair of these, I got a set that were ran for 3 days (practically new) for 100$ shipped.
Also, I make a rear adapter to use 11.1" rotors, and soon to have one to use the 10.2" rear brakes (but won't be making one that can take the stock 9.4" like this). I made some that put the rear NSX calipers on, but will probably not be making them for the public (yes a drum to NSX caliper adapter)
Again, great thread, very nice pictures, and exceptionally detailed write up. Lets get this in the FAQ thread of course.
Cannot PM you. Hit me up if you are still making these. Thanks
Old Nov 12, 2017 | 08:25 PM
  #88
theYBLEGAL's Avatar
Loved
https://scarebird.com/index.php?rout...product_id=116
Old Nov 12, 2017 | 08:51 PM
  #89
NickRN81's Avatar
Thank you so much
Old Mar 14, 2018 | 12:05 PM
  #90
biggoofy8's Avatar
I drive a '99 LX. Do I need to grab a bigger MC and swap out the brake booster or will the 4040 prop valve and a bigger MC be sufficient?
Old Mar 15, 2018 | 06:17 AM
  #91
Chuii Rodriguez's Avatar
I wish this would work on my 99 cx. I guess I have to swap out the whole trail arm😭😭😭.
Old Aug 2, 2019 | 04:07 PM
  #92
eddie7978's Avatar
why wouldn’t it work?
Old Oct 30, 2019 | 09:44 AM
  #93
Jorge Jiménez's Avatar
Work for 01-05 honda civic
Old Jul 31, 2023 | 04:35 AM
  #94
PSU's Avatar
PSU
formerly DxHatchback
Here nearly two decades later to say thank you for this and thank goodness for the photos still being hosted correctly.
Old Jun 25, 2024 | 01:24 PM
  #95
bushyboys97dx's Avatar
Originally Posted by Tobit
FYI, Mark (Scarebird) still has these available. I am ordering a set for my '97 DX Hatchback on Tuesday. Will use new Si calipers, pads, and rotor along with a Si master cylinder. This will be so much nicer than digging through snow filled junk yards right now.
I have a 97 civic dx with rear drums I just want to make sure I get the right one put I can’t figure out with one I need
Old Aug 8, 2024 | 09:42 PM
  #96
milano_vtec's Avatar
Could you use a 5 lug hub like the ctr or itr instead of our 4 lug hub?
hondacl9
Northeast (Sales)
Sep 27, 2012 10:15 AM
imadigitalgod
Sep 2, 2010 10:08 AM
eskimo10
Dec 13, 2007 05:57 AM
antivic
Jun 28, 2005 10:51 AM
civicd15b2
Mar 29, 2005 02:40 PM
