95 del sol b16 in my 96 hatch
i found a b16 out of a 95 del sol and before i do the swap i have a few quick questions. since the motor is OBD1 and my car is OBD-2 what exacly do i need? i think what i need is 99-00 si harness, 99-00 si ecu, 99-00 si dist, and 99-00 alternator? i think im am not sure though. but if i am wrong plz let me know thanks.
Re: 95 del sol b16 in my 96 hatch (hatchy69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchy69 »</TD></TR><TR><TD CLASS="quote">i think what i need is 99-00 si harness</TD></TR></TABLE>
NO! Use your stock civic harness and just add wires for vtec, etc.
The 99-00 harness will only cause you a ton of headaches...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">99-00 si ecu</TD></TR></TABLE>
You really want to use an impossible-to-find OBD2 P30 from a 96-97 Del Sol vtec.
Instead, I suggest an obd1 p30 stock, or a chipped p28 w/ p30 maps. You will need a obd2a->obd1 jumper harness
(you can use the p2t ecu...but you would need an obd2A->obd2B jumper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">99-00 si dist</TD></TR></TABLE>
that will work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">stick gsr</TD></TR></TABLE>
Linkage? All b series (EXCLUDING Del Sol) are the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">and 99-00 alternator</TD></TR></TABLE>
Just get an obd2 alt, theyre all the same
that will work
h8ted ek
10
08-03-2007 08:44 AM
