95 civic underdash wiring, need help asap
So today I was driving and all of a sudden the wiring under the pass side of the dash started to smoke, I pulled over right away poped the hook and unhooked the negitive battery cable. I pulled the carpet back to see wires just melting away and smoking. So after being mad for a few min's I thought ok I still have my car. The car is a 95' civic dx with a d15b mini me swap. I need to figure out what this wiring is and does, I'm not driving the car till then. Can I just get a new section of wiring this stuff is pretty well toast. here is some pictures of where it is can any one tell me what it does and if its pretty easy to get a new section plug to plug, and where it plugs in to on the other side? Its on the pass side under the glove box and goes up and looks like it connects to the heater blower after that I'm lost. It is on the far right side and comes in from the motor bay.
thanks alot
thanks alot
Re: 95 civic underdash wiring, need help asap
I found this : http://www.hondaautomotiveparts.com/...5=WIRE+HARNESS
number 1 on that. Please dear god tell me it's not that. It should unplug from some where else shouldnt it or is it all wired in together with everything?
thanks,
Wil
thanks,
Wil
its not that part. but thank you. Its the other part that goes up in to the motor bay. it sucks. I found out why it shorted though. There was exposed wires that were not taped up or caped off or anything.
So to say, it goes up in to the motor bay, does any one know what harness this leads in to or goes to? I'm going to pull the dash tommrrow and start taking out wiring i'd just like to know where it leads to make it a lil easyier.
thanks,
Wil
thanks,
Wil
Oh look, I can change this
Double reply:
Looks like that is C402 (2-pin) and C403 (10-pin). They both connect to heater subharness A, C721 and C722 respectively. Which side is fried ... to the heater or to the inside of the motor bay? And where is it fried? Fixing this electrical prob seems pretty straight forward - replace the fried wires -- but I might be wrong!
Unfortunately you will need to replace the whole Cabin/Dash harness which is 1 whole harness It starts from the pass side engine bay then goes through the firewall of the pass side to the driver side which is where it will disconnect from 2 plugs (grey and brown). I was just like you, wondering if it was a short harness that could be detached from another harness. Not that easy! And its the harness #1 at Honda, which is over $700, I got mines at the local Jyard for $12 lol. You will need to remove the dash, and ac and heater core and cut up the rubber mat to gain access to the harness. Its a headache and a long process,but its pretty easy. You will see what needs to be removed once you pull the dash out.
I personally changed this myself, just 2 weeks ago. My car died out of no where, and triggered 3 CEL codes which seem weird. Then after trying to crank it so many times, my ECU started smoking. So I thought it was the Cabin harness, so I replaced that. Come to find out it was my engine harness where the IAT plug was it was hacked and wasnt tapped up good, and it was grounding each other. Which lead to other problems!!!
I posted a few help threads here but no luck with any response. Had to go in there and hunt it down and replace it myself. It was also my first attempt at replacing it. Aslong as you have some wrenching knowledge you should be fine.
Hope that helps!
Good Luck
Hope that helps!
Good Luck
Well thats good and bad. I was figuring as much for the hole harness but, hoping for somthing simple which never happens with honda's. Ahhh.... I wish I would have looked over wiring the 1st night I had the car. Oh well live and learn and I should have known with a swaped car. Well thanks for the help. Off to the j/y this weekend to find the wiring.
thanks,
Wil
thanks,
Wil
shanaou
12-16-2007 07:00 PM
bluebird
05-23-2005 04:59 PM
