95 civic jdmd15b swapped in it..
ok guys
swapped a jdm d15b into the 95 civic eg sedan
everything was good
all of a sudden car wont start
keep cranking.. now it stoped cranking at all
im assuming..
1.battery on car
2.altenator..
3. starter
4. distrub
also when i keep cranking smoke was coming out of the ecu
so i stoped cranking it and left it
its been in the garage for a month now and i wanan get it fixed
i miss my baby
everything was good
im assuming..
1.battery on car
2.altenator..
3. starter
4. distrub
i miss my baby
Re: 95 civic jdmd15b swapped in it.. (labatia)
what harness did you use? Sounds like maybe you tried using the stock JDM harness and some of the wires were crossed and fried something. If not please give more of a detailed description.
Re: 95 civic jdmd15b swapped in it.. (Evil_Wizard)
no my car is an ex canadian i didnt switch the harness
people on here said its a waste of money and to just connect the vtec
Hmmm may want to go back and make sure you did all the wiring correctly. Sounds like you have a power and ground wire wired up incorrectly. Other then that I dont know bro sorry.
thanks
what i was going to do was ground everything for now with other wire.. what wire do you all suggest to use? also should i go buy new alt, starter, dist?
i dont even know if its the relays or fuel pump
I wouldnt buy anything until you figure out what is bad. Could just be wasting money. On the ground though I would probably use 8 or 10 gauge wire to ground everything.
Re: (2.2L)
yah it was before
but now i haev no battery in it i think its dead
and i just checked the fuse which looks dead too
so im gonna try and buy a new battery and a fuse
Re: (labatia)
why did you have to wire vtec if you had an ex? was there a point in swapping basically the same motor into the car? im assuming it has high miles or something....sorry just wondering
Modified by Art In Motion at 8:45 PM 8/6/2004
Re: (labatia)
weird...i dont think ur main relays suppose to fry like that dude...something in your wiring is definatly wrong...just take the time to rerun everything...and the rewiring for VTEC is a good question...
Re: (civicboisi)
well today
infront of my work
sum guy with a honda i think older accord
his car wouldnt start
he called emergency assistent and the guy told me it is the ignition coil on the distrub.. he said no body changes them and just get new distribs
so maybe that could be it
infront of my work
that is one nasty *** lookin' main relay... the pics fuzzy so it's hard to tell, did it fry or is it corrosion?
Re: 95 civic jdmd15b swapped in it.. (I Am Jack)
looks fried and has a whole lot of corossion on it
acid was on it too
my hands were all numb after lol
acid was on it too
Re: (Art In Motion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion »</TD></TR><TR><TD CLASS="quote">why did you have to wire vtec if you had an ex? was there a point in swapping basically the same motor into the car? im assuming it has high miles or something....sorry just wondering
Modified by Art In Motion at 8:45 PM 8/6/2004</TD></TR></TABLE>
he is from canada...so ex doesn't come with the d16z6.
