95 civic DX fuel rail help
Old 01-19-2017, 06:17 PM
adrake43's Avatar
Default 95 civic DX fuel rail help
I had a question about the fuel rail and crush washers as well as the fuel damper that looks like a gear kinda ,,, when taking IT apart off of my d15b7 do I need to just replace the crush washer and I can re use my fuel damper for the end regulator cap ,, or do I have to replace both the crush washer and fuel damper I was doing a mini me swap and it pissed out fuel so this is why I'm asking
Old 01-19-2017, 10:41 PM
Hysterically Calm
TomCat39's Avatar
Default Re: 95 civic DX fuel rail help
Your description is a little challenging to know what parts you are talking about.
I can advise that all crush washers are supposed to be replaced every time.
Please use the picture below to call out part numbers for the anything else you are talking about. It might be a bit easier to understand.
Old 01-20-2017, 04:41 AM
mk378's Avatar
Exactly where is it leaking?
If it is coming out of the end of the damper, where the little plunger is (usually under a plastic cover), you need to replace the damper. Otherwise that part is reusable. If it's at a crush washer, try reassembling with new crush washers. You need exactly one washer on each side of the banjo fitting (which has the hose attached).
Old 01-20-2017, 06:15 AM
Resident Gearhead
BryanM.'s Avatar
replace washers
reuse damper
Old 01-20-2017, 07:45 AM
Hysterically Calm
TomCat39's Avatar
Now I get to look like an idiot....
What part is the damper?
Old 01-20-2017, 08:22 AM
Resident Gearhead
BryanM.'s Avatar
lickety_britches
04-22-2009 06:19 PM
hannslebo
03-06-2009 05:19 AM
johnwohl
02-10-2008 11:07 AM
chirp the 1-2
08-31-2005 08:11 AM
Quick Reply: 95 civic DX fuel rail help
