94 civic ex fuel injector removal
Just baught ANOTHER civic ( 94 ex 5 spd) and this weekend im giving it a full tune up. I looked all over the internet and cant seem to find any videos or pics of where they are and how to remove them.
Re: 94 civic ex fuel injector removal
I Just want to make sure everythings flowing properly the car seems to pick up slow and the mpg isn't the same as my other civics. I already replaced the fuel filter.
BAHAHA looks like I'm gonna have to do another one of my pictures. Hang on partner, Ima hook you up with a picture that shows the injectors.
The Grumpiest
The injectors do not need to be touched to do a tune up. Just check teh plugs to see if you're running rich/lean. I predict trouble here.
will do soon. quick question everytime I shift into reverse the gears grind and it acts likes its in neutral. but if I double clutch it goes in smooth and works fine. is that a sign of a bad syncro. or bent fork?
Reverse can be a pain even when it's fine. Is the clutch pedal spongy or low?
No. No buddy. Don't worry about it, my car does the same thing. Reverse isn't synchronised like the other gears, so sometimes you will grind it when shifting into reverse. You can stop the grinding by shifting into another forward gear, except for 5th gear, and then immediately shifting into reverse. I use 3rd gear because it is easiest. You cannot use 5th gear because there is a safety feature preventing accidental 5th-Reverse shifts when a 5th-4th downshift was desired. Try it when the car is off. Put it in 5th gear and then try to directly slide it into reverse. It shouldn't go.
hj
09-29-2003 03:31 PM
