94 civic d16z6 wont start
i have a 94 civic d16z6 wont start.was running fine. ran out of gas, put more in but now doesn't want to turn on. any body know what could be a problem???
Re: car wont start
Check to see if your actually getting spark. Then check to make sure that your actually getting fuel. Also I know it sounds stupid but did you put more gas into it. My brothers car wouldnt start and turns out he had no gas in the tank. Try and give it a little gas while your turning it over.
Re: car wont start
INJECTORS ARE GOING TO HAVE NOTHING TO DO WITH THE ENGINE NOT TURNING OVER! Check your battery and your distributor. Neither of those. Check spark plugs and wires. If you don't know how to do either of the four, read the manual.
Last edited by Former User; 12-15-2011 at 09:49 AM. Reason: Thread clean up. Keep the tech discussions civil.
Re: car wont start
Check for spark
Last edited by Former User; 12-15-2011 at 09:51 AM. Reason: insulting comment deleted. Enough is enough.
Re: car wont start
Injectors are gunna be one of the last few things of why the engine won't start. Basics 101. Thus spark is what I said next. Well wires and plugs.
Re: car wont start
there is spark. new wires,plugs,rotor,ignition module. cleaned injectors tested on car to make sure they are spraying properly. checked all fuses.
