94-95 civic dash into 92-93?
Old Mar 2, 2005 | 09:40 AM
johnny hatchback's Avatar
Default 94-95 civic dash into 92-93?
I know the gloveboxes are different but will the glovebox still be useful or is there a way to make it useful when swapping these two dashes? I've seen how that hydraulic looking piece is on the 94-95 dash that holds the glovebox in but is there a way to swap dashes and still have a glovebox thats not broken?
johnny
Old Mar 2, 2005 | 10:29 AM
dantastic's Avatar
Default Re: 94-95 civic dash into 92-93? (johnny hatchback)
i hear if you have a 94-95 dash, you need the 94-95 glovebox to clear the pass. airbag area. i'm sure you could use a 92-93 box with a bit of trimming. with a 92-93 dash, you can use any 92-95 box
Old Mar 2, 2005 | 10:30 AM
Ignitecivic's Avatar
Default Re: 94-95 civic dash into 92-93? (dantastic)
i thought the 92-95 civic interior parts are interchangeable.
Old Mar 2, 2005 | 02:41 PM
Default Re: 94-95 civic dash into 92-93? (Ignitecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic &raquo;</TD></TR><TR><TD CLASS="quote">i thought the 92-95 civic interior parts are interchangeable.</TD></TR></TABLE>
they are for the most part, but the glovebox is different from those years because of the pass. airbag i assume.
Old Mar 2, 2005 | 02:53 PM
balistik's Avatar
pretty much the same. just the passenger airbag. glove and some other little stuff. 92-93, 94-95. 94-95 also have the rear speakers i believe. maybe only si's.
Old Mar 14, 2005 | 02:11 PM
Mrfeee1's Avatar
Default Re: (p28jspeceg6)
Funny...i just did my swap with a friend yesterday. They are different. he had a 93/black and I a 94/gray. almost everything matched up but both boxes didnt fit due to the airbag. we're both gonna need 94+ boxes. its a long story but yea that the case. personally i dont wanna do any modifications that are too weird to make it fit so the best bet is to find a 94+ box.
Old Mar 15, 2005 | 05:53 PM
jDm_eDm's Avatar
Default Re: (Mrfeee1)
bump good info...u shud go get the itr dasH looks SWEEt
Old May 6, 2005 | 09:02 PM
93civicsedan's Avatar
Default Re: (eG_LsV)
will the coupe or hb dash fit in a sedan? i want to get a black dash for my 4dr.
Old May 6, 2005 | 09:07 PM
eg8000rpm's Avatar
Default Re: (93civicsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civicsedan &raquo;</TD></TR><TR><TD CLASS="quote">will the coupe or hb dash fit in a sedan? i want to get a black dash for my 4dr.</TD></TR></TABLE>
Bump.... I got that puke brown colored dash in my 93 sedan, black would look much better
Old May 8, 2005 | 01:56 PM
O3DigitalBath's Avatar
You should have no problem putting a 94-95 dash and box into a 92-93 car...
if you are putting the 92-93 dash and box into a 94-95 car you have to remove this big L shaped metal bracket and the the box goes right in, otherwise it will hit that, that bar won't be needed anymore since you'll be removing the airbag, I had to do that a while back when I swaped my black dash in
Old May 8, 2005 | 02:30 PM
longbeachpurplecivic's Avatar
Default Re: (O3DigitalBath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O3DigitalBath &raquo;</TD></TR><TR><TD CLASS="quote">You should have no problem putting a 94-95 dash and box into a 92-93 car...
if you are putting the 92-93 dash and box into a 94-95 car you have to remove this big L shaped metal bracket and the the box goes right in, otherwise it will hit that, that bar won't be needed anymore since you'll be removing the airbag, I had to do that a while back when I swaped my black dash in</TD></TR></TABLE>
92-95 are all interchangeable dash wise, and center consoles.. yes glove box from 92-93 wont clear 94-95 cause of airbag but you can still use it if you dont mind it rubbing a little, you dont hear it but you feel it.
Old May 13, 2005 | 12:14 AM
^I know they are...I have a 92 si dash in my 94 DX, but I also had to remove a metal bracket to get the 92 box to close, it wasn't even close to closing without taking that out....
Old Dec 19, 2023 | 03:28 PM
Bobbybands's Avatar
Got a question I'm seeing different answers.. I've got a 95 civic going Saturday to buy a parts civic but it's a 93 so yall saying the 93 dash will fit but I have to use my 95 clove box? Both air bags have been removed in my 95
HondaBoy954
May 14, 2007 09:42 AM
civiceg500
Jul 22, 2004 07:15 PM
egg_baLLa
Jun 7, 2004 02:22 PM
-[95cxhatch]-
Jan 23, 2003 08:35 PM
The G2 Racer
Jun 16, 2002 08:38 PM
