93 EG6 B16 axle question
Old 12-31-2008, 02:15 PM
fcfguitarist's Avatar
Default 93 EG6 B16 axle question
I have a 93 SI hatch with a B16a swap, I bought the car with the swap already done, and i'm in the process of replacing my driver side axle. I was wondering what axle would I need to buy to replace it.
Old 12-31-2008, 02:29 PM
T3KNiQe's Avatar
Default Re: 93 EG6 B16 axle question
Axles from 94-97 Del Sol DOHC VTEC
Axles from any model 90-01 integra
Axles from 99-00 civic Si DOHC VTEC
Old 12-31-2008, 02:30 PM
Seagull Management
94EG8's Avatar
Depends on what intermediate shaft was used, if it was a cable intermediate shaft then '90 - '93 integra axle, it was a hydro intermediate shaft (more likely) '94 - '01 integra/'94 - '97 Del Sol Vtec/'99 - '00 Civic Si axle. Note that you can use a cable intermediate shaft and axles on hydro tranny and vice versa, although it does require replacing the drivers side axle seal. (I think the passengers side uses the same seal in both cases, but I could be wrong on that point)
Old 12-31-2008, 02:35 PM
T3KNiQe's Avatar
It doesn't matter weather the transmission is hydro/cable, you just want axles from any B-series which the cars I listed above ^^^ are all B-series.
Do you have ABS? If so just go get the axles for a 2000 civic Si to make it easy.
EDIT: Oops!!! you do have ABS!!
Old 12-31-2008, 02:42 PM
Seagull Management
94EG8's Avatar
Transmission no, intermediate shaft matters though. '90 - '93 integra axles have a female end on the inside where they mate to intermediate shaft. Hydro B-series axles have a male end.
He doesn't have ABS, the only year ABS was offered on Si hatches was '94.
Edit, I may have been wrong in which intermediate shaft had which end, but the point is one has a male end and one has a female end.
Old 12-31-2008, 02:46 PM
thanx for the reply guys I believe its hydro and now that i think about it i think i remember the guy I bought it from saying he used 00 si axles.
Jwbetley
07-18-2009 04:36 PM
LSegHatchy
04-01-2009 09:29 AM
SlammedEG6
Suspension & Brakes
08-29-2008 03:14 AM
CIVIC TYPE R 52
02-16-2003 08:41 PM
chris5n6
03-21-2002 06:08 AM
Quick Reply: 93 EG6 B16 axle question
