93 del sol ecu problem codes run nonstop
hey wsup,
new to the site but use it alot when ever i run into a problem. Couldn't find a thread for this and i wanted to get some opinions on what could cause this.
check engine light was on so i ran codes using the paperclip method
cars a 93 del sol and the readout was just a series of nonstop long flashes (ran it for about 20 mins wouldn't quit blinking)
so im thinking it has something to do with the ecu maybe a relay
any suggestion on what to check to figure this out
had a civic front end conversion and there might be a short in the headlight wiring from previous owner not sure if this could cause this
talks to himself
Re: 93 del sol ecu problem codes run nonstop
The ECU will continue to tell you what code(s) are stored. It won't stop flashing the codes until you unplug the clip.
If the pause between flashes is the same length each time, it sounds like you have a code 10.
Check this link in the FAQ. https://honda-tech.com/forums/honda-...lists-1901557/
grinch559
05-23-2012 07:05 PM
91ef-si
34
08-26-2010 02:31 PM
2point2
09-17-2004 04:30 PM
