93 D15B8 to 96 D15B
93 D15B8 to 96 D15B
Ok so this may sound dumb but for the time being a B16A swap is not economical for my pocket. I am pulling a D15B from a 96 EK this week and will be putting it into my 93 Canada built CX Hatch. I would guess that the only thing really different would be obd1 to 2 as far as wiring goes??? I have seen some guys run a obd 1 harness and ecu with this swap....essentially it's the same motor! My only concern is wiring....the reason I am doing this is because the motor is FREE and my D15B8 has a badly worn wrist pin on the number 2 piston and a bent valve on the exhaust side on the number 2 cylinder. I had originally decided to run it till it blew, but I have a long communte everyday and dont want to be stranded! Any advise would be appreciated...if you dont have advice please dont comment....this is my DD and I need it running...
the Civic the motor is coming from is a 1996 D15b DX hatch non vtec which is OBD2 My 93 CX hatch has a D15b8 which is a non vtec 8 valve engine. The only difference is that the 96 motor has an obd2 ECU and O2 Sensor also it's a 16 valve head. Like I said it's free...from searching for about a week now I have found that the swap should just drop right in...like I said before the only thing is that I will not be getting the wiring harness from th 96 with the motor...I will have to transfer my harness from my 8 valve D15 to the 16 valve D15 that will be going in. I need to know what other wiring will need to be done....I have been having trouble finding any info on this...mostly because every opts to do a DOHC Swap....I have done about 15 Dohc swaps to EG's in the past but never D15B8 OBD1 to D15B OB2.....AGAIN Both Engines are non vtec...
Seagull Management
Re: 93 D15B8 to 96 D15B
If the '96 is an original D16Y7 engine you can either reuse your intake and exhaust manfolds and ECU from the B8 or get ones from a D15B7 or D16Z6 (preferable) and run a P06 ECU (you will need to wire in a 4 wire O2 sensor using a P06)
hollywood96ex
01-30-2009 01:56 PM
DJNauTicz
01-22-2007 10:06 AM
