Obd2a to obd1 I got spark and I'm not hearing the fuel pump prime.
Old 05-22-2017, 07:03 PM
Cheeseburgers's Avatar
Default Obd2a to obd1 I got spark and I'm not hearing the fuel pump prime.
97 auto civic lx, swapped it to manual.
D16z6 bottom d15b head with a chipped p28 using obd2a injectors, I had to lengthen the map, tps, and converted the iacv to two wire iacv, and cfk bypass done.
I am getting spark but I don't believe I'm getting fuel, the check engine light dose not shut off after two seconds it just stays solid and I'm not hearing the fuel pump prime, though when I disconnected the fuel line from the filter gas was present, maybe I have the wrong injectors I don't know any help would be great. Thanks!
Old 05-22-2017, 07:24 PM
Default Re: Obd2a to obd1 I got spark and I'm not hearing the fuel pump prime.
Oh crap I just realized I posted in the wrong category.
Old 05-23-2017, 05:31 PM
Bump could really use some help.
Old 05-25-2017, 02:33 AM
Technical Hero
HondaPartsHero's Avatar
What injectors did you use? Did you connect the thermostat ground?
Old 05-31-2017, 05:37 PM
Yes I figured it out, the sst chip in the ecu was in the wrong way. I got it running but I'm having trouble with timing now. I have a y8 can gear to compensate for the half tooth off difference, but I can't get it right. I was told it had a stage two aftermarket camshaft, but after some research I believe it is just a jdm cam. I still can't figure what head the cam is for, I've look at related threads but nothing has the same stamps. On the dizzy side of the cam it has B526 stamped on it. It would help to know what head the cam belongs too d15b,z6,y8 etc.
Cheeseburgers
05-31-2017 05:50 PM
Z0831xiz
06-17-2013 05:14 AM
jcrredrex2012
12-15-2012 08:24 PM
CRXWOLSKI
17
01-10-2008 03:11 PM
Boriqua0555
06-06-2004 05:01 PM
Quick Reply: Obd2a to obd1 I got spark and I'm not hearing the fuel pump prime.
