93 Civic coupe MASSIVE wheel wobble
I have a massive wheel wobble from the L/F wheel when driving.I put the car up on jack stands and had my friend put it in drive.The L/F wobbles back and forth like crazy.There is no play in the wheel,nothing loose,and I rotated the tires on that side back to front and still the same.....What else could it be????
Re: 93 Civic coupe MASSIVE wheel wobble
Mine is doing just as described, CHECK THE RACK AND PINION, check for leaks around seals, and POWER steering fluid loss.
My tires Wobbles LEFT TO RIGHT, NOT up and down.
You can see the bar going into Rack and pinion move, where it should NOT without force.
EDIT: by OP, No play in wheel would leave me thinking bearing is FINE
Well my rack is shot and leaking,but there is no play in the wheels so I don't think it can the rack and pinion
or can it be....
or can it be....
Left to right play in the wheel is a rack, inner tie rod, outer tie rod, upper or lower ball joints or even the strut top hat. All can cause left to right place in the wheel/suspension.
A bad rack will cause wheel woble above 55 mph. Get the rack and tie-rods changed and see if the wobble is still there. If it is, try getting the wheels rebalanced...if that doesn`t work, change the bearings..
I dont think theres set MPH
EDIT: Wheel ballance $12, Rack, and tierods $300+... Start small....
If the rack and pinion is shot it will wobble as mine does.... The bearing would cause a different wobble... You just have to play with it, and watch what parts move, and how....
Sounds like you reposted and are unsure now exactly how it wobbles....
If you can do it without force, and its moving around, its NOT the rim/wheel, its somewhere in the stearing. I dont know enough about ball joints or tie rods....
Rim I would eliminate...
I re-read the thread, I vote bearing now too
How does the CV shaft look?
though if the wheel bearing was bad wouldn't it be making noise???
jack the car up and grab the tire at the nine and the three o clock positions, wiggle it side to side, does it wiggle? observe the outer and inner tie rod for movement.
now grab the wheel at the twelve and the six o clock and wiggle up and down, if the whole wheel moves and nothing else moves its the wheel bearing.
Rickdogg
12-22-2009 10:16 PM
EG_93Civic
13
02-08-2006 08:01 PM
blackccoupe
05-23-2005 04:19 PM
