93 2dr teg seats in 93 civic hatch?
will 93 teg seats bolt into a 93 civic hatch or will it have to be custom mounts? looked thru the faq but didn't find anything on it.
Re: 93 2dr teg seats in 93 civic hatch? (civicwagonman)
No they will not bolt right up. If im not mistaking only 2 of the bolts line up. You have to modify all the rails.
If you search im sure you will find more info.
https://honda-tech.com/zerosearch
Re: 93 2dr teg seats in 93 civic hatch? (jdmgsr_ej1)
it should there might be one that dont i just put ep3 seats in my 96 ek. all matched except one, wen in doubt bust out the mig
Re: (bpwrdeg)
I tried to put a set in my 93 coupe and they weren't stable... I think only 2 bolts lined up...
You can swap your seatpans I THINK... but I seem to remember looking at that and thinking it would work due to how the hinge is mounted differently on the 93vic vs the 93teg.
Good luck.
Good luck.
thanks I'll give it a try I guess. didn't want to mess with it this morning when it was 18 degrees outside. gotta clean the garage out so I can use it again.
bringmyownend
04-04-2009 06:44 PM
civicwagonman
06-14-2006 08:57 AM
aonick
07-21-2002 08:14 PM
