92 VX Confused?
92 VX Confused?
My buddys got a bone stock 92 vx (z1) he is having a weird issue. He says it pulls fine through first and second but in 3rd gear it all of a sudden loses all power after 3k. I have no idea. He says its only in 3rd gear so far. Any Ideas?
Re: 92 VX Confused? (truevietluv636)
well ya i know that. but he said it was sudden thing. never done it before. just seddenly lost power. stopped bulling. but car still runs and drives. just bogs over 3k in third
Re: 92 VX Confused? (EGLUVN)
Yeah my VX pulled in 1 and 2 also, then started to slow down in 3, 4 &5... My VX tranny went out the other day. Tell him to get an Si tranny or a D16Z6 swap like me, I'm in the process of doing mine this moment
I think we may need a little more info to solve the problem.
the problem I had with my tranny was it was whining in 1st and 2nd it poped outta gear when I let off the gas cuz the syncros were all fucked. It doesn't really sound like he needs a new tranny.
Re: 92 VX Confused? (CapnKrunch)
my tranny was messed up too.... kept winding and slipping in a couple gears... soo right before i swapped it, i took the car down the block and mashed it in 2nd gear... 30 some seconds later i hear a big bang... 2nd gear broke... sooo popped it in first and drove home, pulled out the tranny and lots of chunks of metal falls out... swapped in a cx tranny (feels just like the vx tranny)...
now im also working on a d16z6... going to do new gaskets or rebuild if i get some money.
Location: Land of the Hillbillies and Shotguns, Ontario, Canada
we need some more info of how the car is behaving. could be clutch is slipping, engine is bogging, etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truevietluv636 »</TD></TR><TR><TD CLASS="quote">my tranny was messed up too.... kept winding and slipping in a couple gears... soo right before i swapped it, i took the car down the block and mashed it in 2nd gear... 30 some seconds later i hear a big bang... 2nd gear broke... sooo popped it in first and drove home, pulled out the tranny and lots of chunks of metal falls out... swapped in a cx tranny (feels just like the vx tranny)...
now im also working on a d16z6... going to do new gaskets or rebuild if i get some money.</TD></TR></TABLE>
yeah same thing with mine. mine leaked oil like a bitch. i just finally said expletive it to the whole d15z1 thing and got a d16z6 complete with the tranny clutch n harness with 87k for $550
Ek Forever y0!
How many miles on the car?
If over 130k it's possible the 3rd gear or the final drive is going out. The car is also a few years shy of being as old as me.
Go Tigers!
Re: 92 VX Confused? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">How many miles on the car?
If over 130k it's possible the 3rd gear or the final drive is going out. The car is also a few years shy of being as old as me.</TD></TR></TABLE>
I have never even heard of a final drive wearing out. That's like wearing out a connecting rod.
Sounds like the clutch is slipping. Keep in mind that the vx 3rd gear ends at like 130, that car is very very weak with that 92hp d15z1.
Ok. So what would be your recommended fix. Cause it sounds to me like your king **** when it comes to trannys (bense) no joke. So just throw on a dif tranny and go from there. Or just say f it and go ls swap?
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGLUVN »</TD></TR><TR><TD CLASS="quote">Ok. So what would be your recommended fix. Cause it sounds to me like your king **** when it comes to trannys (bense) no joke. So just throw on a dif tranny and go from there. Or just say f it and go ls swap?</TD></TR></TABLE>
If LS swap is even an option for you, LS swap by far over getting a different tranny for that peice.
GDD's Dr. Phil?
Since it is dying out at +3k rpm I would check to see if it is going into vtec, vtec-e, or 16valve mode however you want to think of it. 3k is the crossover point so maybe it is not locking in the four extra intake valves and is running on the 16 valve timing and fuel curve while still on 12 valves past 3k rpm going rich and bogging?
Go Tigers!
I don't think that there's anything wrong with the transmission. It could be a slipping clutch, but then his RPMs would shoot up, which it doesn't sound like that.
I mean nobody is going to be able to diagnose anything until he verifys that everything else is in check
plugs
wires
sensors
ignition timing, etc.
plugs
wires
sensors
GDD's Dr. Phil?
keep that vx just the way it is in all of its 55mpg glory... Buy another car and build it for performance with the fuel savings!
Re: 92 VX Confused? (oneludesol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol »</TD></TR><TR><TD CLASS="quote">Since it is dying out at +3k rpm I would check to see if it is going into vtec, vtec-e, or 16valve mode however you want to think of it. 3k is the crossover point so maybe it is not locking in the four extra intake valves and is running on the 16 valve timing and fuel curve while still on 12 valves past 3k rpm going rich and bogging?</TD></TR></TABLE>
That's what I was thinking, it's probably running on the 12 valves or whatever it is and choking the **** outta the engine past VTEC-E engagement.
Though that'd throw a CEL...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">
Sounds like the clutch is slipping. Keep in mind that the vx 3rd gear ends at like 130, that car is very very weak with that 92hp d15z1.</TD></TR></TABLE>
It's possible, but I think he'd notice his RPM jumping or the engine sound not being in sync w/ the power (it's usually pretty obvious).
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGLUVN »</TD></TR><TR><TD CLASS="quote">what the hell would u want with that</TD></TR></TABLE>
I guess it's the magic MPG engine/tranny setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol »</TD></TR><TR><TD CLASS="quote">keep that vx just the way it is in all of its 55mpg glory... Buy another car and build it for performance with the fuel savings!</TD></TR></TABLE>
My VX only averaged about 32 MPG.... on a bad tranny.. F*** those long *** gears.
I guess it's the magic MPG engine/tranny setup </TD></TR></TABLE>
I've heard that if you put the z1 head on the z6 block you have 180 hp at 11:1 compression.
