92-up civic 94-up integra ignition switch interchangeable?
Old 07-25-2005, 09:16 AM
dognutz's Avatar
Default 92-up civic 94-up steering column interchangeable?
Does any one know if ignition switches are interchangeable between these models and years( 92- up civic and 94- up integras) ? I have a 92 SI and I need to know if any of the integra ignition switches will work? Any help will be greatly appreciated.
Modified by dognutz at 4:49 PM 7/26/2005
Old 07-25-2005, 10:14 AM
B18CR_EJ2's Avatar
Default Re: 92-up civic 94-up integra ignition switch interchangeable? (dognutz)
only way they are interchangable is if they are the same series.. does your civic have a b16 or a d series... because if its a b16 you would be able to swap with any model integra.. LS RS GS GS-R etc..
Old 07-25-2005, 04:43 PM
dognutz's Avatar
Default Re: 92-up civic 94-up integra ignition switch interchangeable? (B18CR_EG)
I got the 1.6 vtec. thanks for the info. This ign. will work fine.
Old 07-26-2005, 03:44 PM
dognutz's Avatar
Do you happen to know if the same is true of the steering column. I have the b16 with adjustable height and the parts car is an integra with adjustable hieght. I was wondering if the steering columns are the same i.e. key ways ( for steering wheel) are in the same location and all.
Thanks for the info before and fast response.
6KAOS6
02-20-2011 10:49 AM
JDMCRX
04-28-2010 04:25 PM
erik66
08-23-2007 08:48 PM
dognutz
04-29-2007 11:12 AM
H22AJSPEC
03-09-2006 08:23 PM
Quick Reply: 92-up civic 94-up integra ignition switch interchangeable?
