92 eg si ?
92 eg si ?
ok i have a eg hatch and i swapped in a jdm single cam but its from a ek and the idles is all funky.. i checked the dizy everything is ok there adjusted the idler screw and it seems to be where it needs to be..now the idle goes up and down from 2thou rpm everytime i start the car and after maybe five minutes it stops.. anyone knows what the problem is i would greatly appreciate a answer for this question if anyone knows the answer, thanks!
Re: 92 eg si ?
Need more detailed info. Engine code? Ecu code? Check engine light on? What codes is it throwing. Lots of things it could be. Dizy? You mean distributor??
EGee Eddie
16
05-12-2013 08:38 AM
