92 civic si sunroof replacement
Re: 92 civic si sunroof replacement (Retroo)
tools: philips, ratchet with 10 or 12 or 14 (im sure its a 12 though, sorry), needlenose pliers (i did)
take off you headliner. probably has 3 or 4 plugs, if you got the handles above the passenger side (i forgot what theyre called) take them off also as well as your sun visors. and the domelight, remove the harness connected to that.. (the obvious)
you should see the sunroof. theres a screw at each point of the sunroof, i think it also has two more screws at the end of the rails.
remove the harness attached to the sunroof as well as i think 4 rubber hoses.
i hope this helps i stripped my car a while ago and this is what i can remember, would be exact on some info if i still had the car to confirm with
ken9
02-10-2010 07:45 PM
