92 civic si radiator fan won't turn on
Old 04-30-2015, 08:49 PM
Hondatechnoobi's Avatar
Icon6 92 civic si radiator fan won't turn on
So I have a 92 civic si with a d16z6
It has a small turbo which was put in before I had to car, the turbo takes the place of the condenser fan.
My problem is the radiator fan I have doesn't turn on when the car starts to overheat ( needle going past half).
I know the fan works along with the relay and fuses, I currently changed out my ect, thermostat and fan switch
But i shorted the fan switch before I replaced it and the fan turned on with the key in ignition but after I replaced the switch the same thing would happen
I have also bled the coolant system
Thank you very much for your feed back
Old 04-30-2015, 09:37 PM
Fish Twig
tony_2018's Avatar
Default Re: 92 civic si radiator fan won't turn on
How did you check your fan switch?
Old 04-30-2015, 09:42 PM
By putting a paper clip in the terminals and turning the key
The fan comes on
Doesn't that mean the fan switch is bad ?
But I just put a new one in but still nothing
Old 04-30-2015, 09:46 PM
Thank you for the reply btw
Old 04-30-2015, 10:38 PM
Fish Twig
tony_2018's Avatar
No, it does not, what you just did was complete the circuit for the fan to come on. You didn't not test the actual switch the plug was connected to.
Old 05-01-2015, 08:08 AM
Former User's Avatar
Describe exactly how you bled the cooling system.
Old 05-01-2015, 08:55 AM
Hey I actually was looking at a forum where u described and showed a picture showing how to properly bleed the system
Old 05-01-2015, 08:56 AM
But when gauge went past half I terminated the process
Old 05-01-2015, 08:57 AM
What is it suppose to read? 5 volts? Or continuity
Or boil water and test it that way?
fatl13ert
10-22-2012 12:41 AM
kirkland08
03-05-2011 01:15 PM
civichm
10-18-2010 05:31 PM
ngoldsmith1@gmail.com
10
11-27-2008 01:04 PM
ViXoN Hatch94
02-04-2006 07:53 PM
Quick Reply: 92 civic si radiator fan won't turn on
