92 civic Si with JDM ITR motor??.....Im being called out!!!! need advice from civic guys!!!!!!!!!!!!
how fast do these bastereds run with just the JDM motor swaps? he has nothing else just the b18c5 swap in his 92 hatch si.....im running my 2k itr with JUN head package and jun header with 2.5 inch exhaust i ran a best of 13.8 on street tires. can i beat him?
Re: 92 civic Si with JDM ITR motor??.....Im being called out!!!! need advice from civic guys!!!!!!!!
Close call, if you look up a user B18c5-EH2 , he used to have a 92 si hatch and then converted to a 92 cx hatch. He should have times for you, but if you run a 13.8 best, I'd say it'd be neck and neck depending if the 92 si pig did any weight reduction.
P.S. Please keep it off the street and take it to the track.
These type of things should only be done on the track and it will be just needed some idea thanks
No problem, good luck and don't forget to shed some weight off the itr.
Former Moderator
If the hatch guy can drive then I'd say you will have an extremely close run.
I ran a 13.9@101mph on street tires in my full interior'd 1992 Si hatch with a USDM ITR swap with only an intake, exhaust, and ECU - stock cast-iron USDM ITR exhaust manifold too.
If he had a CX then...
It will be a close run...if he can drive, but does the 200 lbs from a CX to a SI really matter that much? good luck let us know what happens
2000gt
Southeast (Sales)
01-12-2009 03:00 PM
