92-95 civic kill switch fail help find issue
Old 04-17-2014, 01:30 PM
edwinie26's Avatar
Default 92-95 civic kill switch fail help find issue
DX 93 hatch auto to manual conversion. so I thought hey maybe I could connect a kill switch to these two cables (Thick Black white and Thick Black red)
I thought this since they connect either way
not my picture took it out of another thread
I had them soldered together for a while to drive, but when I put in a 25A push button and tried to turn the key smoke came out of somewhere.
what did I burn/damage?
I know I should have put a relay but what else can I say tried to take an easy way :/
Old 04-17-2014, 02:07 PM
edwinie26's Avatar
Default Re: 92-95 civic kill switch fail help find issue
found the thing that smells burnt its under the steering column near the center console has about 5 cables attached to it small rectangular thing with like a greenish fiberglass plastic
kind of looks like this but black
car wont turn on. fuel pump turns on
Old 04-17-2014, 04:04 PM
kevpple's Avatar
Was the part that got burned a control module? If so can you check the model number on it?
Old 04-17-2014, 04:13 PM
JoeBlue's Avatar
Googling the model number should tell you what it is.
Old 04-17-2014, 04:26 PM
nub
nub's Avatar
That looks like a harness for an aftermarket keyless entry or alarm.
Old 04-17-2014, 05:37 PM
edwinie26's Avatar
It came with the car when I got it here is the original let me upload it
Old 04-17-2014, 05:52 PM
edwinie26's Avatar
Not really like a keyless module.. It has like a small plastic plate ? Some kind if resistor?
everything in my car is manual. I'll look for the #
Here it is
Old 04-17-2014, 06:01 PM
Hysterically Calm
TomCat39's Avatar
So what kind of chevelle is this?
Car information makes life a lot easier for people to help you. Beyond knowing it's a Honda, we have to assume it is between a 1992 and a 2000. And assume it's a civic, then we have to guess if it's a CX, DX, Si, and LX or maybe it's the VX or is it the Ferio from overseas?
General rules is full car information is disclosed within your first post in the Tech forums.
Old 04-17-2014, 06:12 PM
edwinie26's Avatar
I apologize 93 civic hatch DX automatic converted to manual
Old 04-17-2014, 06:36 PM
Hysterically Calm
TomCat39's Avatar
I could be totally mistaken but the black plug looks quite similar to an anti theft system I remember from the 90's where you plugged an electronic "key" into so the car would start.
That has a few more connections than the one I had in a toyota pickup but it looked a lot like that. Don't remember the name.
Old 04-17-2014, 06:47 PM
edwinie26's Avatar
Thanks I'm look for that name
Any other suggestions?
Old 04-17-2014, 08:46 PM
nub
nub's Avatar
^^This. These were common in the 80's and 90's. Really it was a "bunk" starter or ignition cut that used a "key" to complete the circuit to enable starting.
I used to install these for dealerships back in the day and they're stupid simple.
In OP's case his plug has 6 terminals/wires but only 2 of them are actually used. Those 2 wires are gemerally tied to each side of the cut starter wire on the ignition key harness. The "key" for the plug is a plastic handle with a rectangular circuit board that slides in and completes the circuit.
Dealers were supplied with a bypass "key" so vehicles could be moved on the lot or test driven. This bypass key was thae same as the security key except it didn't have the handle. That bypass is visible in OP's last picture.
You should be able to follow the taped harness up to were it's tied to the cars harness. These genarally aren't very stealthy which is why they aren't used any more. Disconnect it and reconnect the cut factory wire.
Old 04-17-2014, 10:15 PM
edwinie26's Avatar
Thank you, I will do this as soon as I wake up
Old 04-17-2014, 11:28 PM
Stancetard Hate Monger
eghatch9295's Avatar
og anti theft. in 2001 or so i had a cutlass with a number pad ignition kill. lol.
Old 04-18-2014, 06:46 AM
edwinie26's Avatar
Lol
Well i took off the bypass key and it looks/smells burnt. It doesn't look like it will stop if from working I could be wrong take a look.
Is there a way I can fix it instead of removing it ?
Old 04-18-2014, 06:49 AM
edwinie26's Avatar
Old 04-18-2014, 10:18 AM
edwinie26's Avatar
TomCat & Nub thank you. I got it to start again.
It was an old style "kill switch"
ooo... the irony!!
TravisCadello
15
02-12-2018 04:20 PM
johnlvs2run
59
11-07-2014 11:48 AM
Black Diamond
02-22-2011 04:16 PM
sevindust2404
02-23-2007 02:23 AM
hatchinprogress
08-27-2004 05:09 PM
Quick Reply: 92-95 civic kill switch fail help find issue
