92-95 civic ex front LCAs fit 96-00 civic hatch?
i'm trying to find out if it is possible to put some 92-95 civic ex front lca's on my 98 hatchback? i'm wanting to put them on my hatch to run sway bars...hehehehe...i would go aftermarket, but that is expensive...plus stock will do...lmk if it fits...if so, i'm gonna go look for some and put them on...
Re: 92-95 civic ex front LCAs fit 96-00 civic hatch? (ek4_b16a)
I don't think so I think your car runs a McPherson strut style suspension and the 92-95 where double wishbone.
Re: 92-95 civic ex front LCAs fit 96-00 civic hatch? (instructor74)
no, EK had double wishbone up front.
I don't know if it will fit or not. I know the rear don't/
Re: (Relic1)
i looked on majestic honda...i dunno, but the part numbers don't match, but if you match the pics together, they are identical...hmmm...i shall just call honda up myself and ask...
anyone else know for sure if they won't fit? or fit?
Re: (ek4_b16a)
yea they will not fit the car 98 civics chaged the chasis so basicaly this is how it is
92-95 civics and 94-01 integras u can iner change parts and u can only use the disc brakes from a integra on a 98 civic.
Ek Forever y0!
Re: (bayeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bayeg6 »</TD></TR><TR><TD CLASS="quote">yea they will not fit the car 98 civics chaged the chasis so basicaly this is how it is
92-95 civics and 94-01 integras u can iner change parts and u can only use the disc brakes from a integra on a 98 civic. </TD></TR></TABLE>
Christ on a crutch the misinformation is astounding.
any 96-00 rear disc from an ex, lx, or si will work on your 96-00 civic.
92-95 can utilize integra brakes, or any brakes found on their chassis from 92-95.
According to this post, an Integra one will work, thus a 92-95 Civic will too.
http://www.jdmcivic.com/forums...68355
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4_b16a »</TD></TR><TR><TD CLASS="quote">i'm trying to find out if it is possible to put some 92-95 civic ex front lca's on my 98 hatchback? i'm wanting to put them on my hatch to run sway bars...hehehehe...i would go aftermarket, but that is expensive...plus stock will do...lmk if it fits...if so, i'm gonna go look for some and put them on...</TD></TR></TABLE>
you should get 99-00 si LCA's & run 99-00 si front sway (same as 96-00 CTR) - for some reason I think you need more than just LCA's if you want to go 92-95/teggy
I hope you have rear sway bar already - if not a front one is gonna make you car understeer even worse... especially if you are not running a LSD
pretty sure if you won't be able to run 92-95/teggy swaybar/LCA's unless you swap out ek for eg subframe, forks & steering rack - the geometry of everything is different
Modified by 6SPD_EK at 11:32 AM 5/22/2007
yeegsr
05-11-2005 11:04 PM
xCIVICx
11-13-2004 09:41 PM
AEGEAN
01-04-2003 02:31 PM
