7G rear drum to disc conversion?
Has anyone done or know of a way to convert the rear drums to rear discs on the 7G(01+) Civic? What is necessary to do the swap (discs, calipers, control arms, etc.) from the 02 Si or RSX?
Re: 7G rear drum to disc conversion? (Session101)
youd want to use the Si's because if you use the RSX youd have to do the fronts as well unless you want 4 lug in the front and 5 lug in the rear
Re: 7G rear drum to disc conversion? (WR93EG)
That is very true regarding the 5-lug pattern on the RSX. I am not worried about that because the lug pattern could be remedied by changing the hub assembly. However, you are right that the Si should be the easiest and less-troublesome of the two. Does anyone know if this conversion has been done yet?
Re: 7G rear drum to disc conversion? (purek9hybrid)
It's been done... go to wwww.7thgencivic.com and do a search, you should find it. It's similar to the conversion used on the older body style non-SI civics.
I'm waiting for someone to actually go buy an Si... then rear end someone... then I get rear disc brakes.
civbeater90
09-16-2004 05:05 AM
