Service check connector CEL behavior
Hello all. Simple question. When I plug in the service check connector, if I have no codes set, what does the CEL do? I was under the impression that if no codes are set then the light stays illuminated and doesn't blink at all. When I short the wires in my '98 HX, the CEL fails to turn on or flash. The CEL passes the self test when the car turns on of course. Is this normal? Or are my service check connector wires screwed up?
The reason I ask is because I'm adjusting the spark timing.
Re: Service check connector CEL behavior
2nd this. It sounds like you may be miss jumping the service connector.
turbo sol
04-02-2009 05:31 PM
streetracerjoey210
08-05-2006 06:28 PM
stealth89hatch
08-15-2005 04:48 PM
