4dr eg... vw style camber
Location: Charlottesville/Newport News, VA, United States
so i think i might be getting a white 4 door eg. I personally hate 4 doors but it has a built motor and suspension. I was curious to know if there were many or any people out there running a wheel/tire combo that would be similar to VW style in that it is at least flush and maybe even some neg camber for the rear. It's probably a dumb idea, but its a 4 door so i might as well do something crazy?
Re: 4dr eg... vw style camber (b18crx88)
look in appearance/cosmetic forums for slammed cars. there are entire groups/threads devoted to it. i dont know any civics running a stretched tire like vw's but im sure someone somewhere has done it.
H-T White Ops
FV-QR
Definitely check the Appearance/Cosmetic section. You could make a thread looking for photos there too. Then if you see something you like, ask about the setup.
Re: 4dr eg... vw style camber (RiddickJordan)
I don't think he's asking about stretched tires. Most Dubbers run spacers to get the poke (rim lined up with or past the quarter). Others rely on crazy offsets and wide rims.
Camber you get with a drop. Look in the air set up thead and you'll see camber I had when dropped. Or you can lengthen the lower control arm or have a new one custom built to give you the same look with less of a drop. I just suggest you find a sponsor for tires.
alacard
Suspension & Brakes
19
06-25-2007 10:39 AM
