205/50R/15 Azenis...tire pressure ?
running on TEIN SS coilovers with rota slips. i need to know what tire pressure i should be running for daily driving and when i autocross. did an search but didnt find what i was looking for. THANX
Re: 205/50R/15 Azenis...tire pressure ? (HUBB)
Really I swore I saw this debate a couple times over there????
Anyways,
Daily I drive on 35 on mine I like really filled treads though.
Auto X I run F 32ish and rear 28ish
I haven't run one auto X day this year so I may have honestly forgot numbers.
Anyways,
Re: 205/50R/15 Azenis...tire pressure ? (DX Hybridizer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DX Hybridizer »</TD></TR><TR><TD CLASS="quote">Auto X I run F 32ish and rear 28ish
(</TD></TR></TABLE>
That's really low for autocross... I may want to try something lower. I usually run 41f/45r -3 if it's cold or rainy.
(</TD></TR></TABLE>
The local autox safety people say 40psi(cold). Not just for Azenis though. It's to avoid tire roll over. I'm sure with the stiffer side wall tires its not such a worry.
Use the factory recommended cold pressure for daily driving. For autocross, a pyrometer will be your bestest friend. It also depends on how you want to fine tune the balance of your car. Personal preference.
be professional
Re: 205/50R/15 Azenis...tire pressure ? (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa »</TD></TR><TR><TD CLASS="quote">That's really low for autocross... I may want to try something lower. I usually run 41f/45r -3 if it's cold or rainy.</TD></TR></TABLE>
Not for Azenis. One of the main features of the Azenis is its extremely stiff sidewall, because it was designed for autocross and road course use. You can run a lower pressure than normal street tires without worrying about the sidewall rolling over.
I have run as low as 20psi in my Azenis at autocrosses without them rolling over. On the street I run 32psi front and 29psi rear, and this is still too much because after 18,000 miles they are worn out in the center from overinflation.
Re: 205/50R/15 Azenis...tire pressure ? (Targa250R)
I run 35 frt and 32 rear. Car is lowered 1.5" with no camber correction. Wear is even after 8000 miles!
ekim952522000
13
08-24-2005 08:02 PM
