2002 Civic EX deck question.
Re: 2002 Civic EX deck question. (Junior.)
what you are going to do is remove the lower cover where the power outlet is once you remove that there will be two 8mm screws not gold but silver under there. once you have removed the screws you will have to pull the whole center cluster out it will come out hard cause honda used way to many clips if some of the clip come out and get lost don't worry cause as long as you did not loose them all you should be fine. good luck if you have any more q's email me back
Deemeetree
07-29-2004 07:06 AM
