2.0 D series
2.0 D series
Hey guys, Im starting another D series project this summer...and Im trying to get a 2.0 litre D series! I already have a spare y7 block (so I can use my axles) and a Y8 head. Anyone have any ideas on how to get the D to 2 litres or is it even possible?? Id like at least a 1.8, but I don't want to have to resleeve the block. I'm also trying to find a reputable maching shop around here to get some headwork done! Thanks guys!
Re: 2.0 D series (Ricey McRicerton)
Send the block the JG/Edlebrock or AEBS racing and have them sleeve and bore to 81mm.
Done.
You can't do **** without sleeving.
My bad....you guys are correct. It's only a 1.85L engine.
Increase the stroke (don't like this idea) to 95mm with the 81mm bore for a 1.96L engine.
Modified by Spade at 11:20 AM 6/4/2003
Done.
Re: 2.0 D series (Spade)
Well what rods/pistons should I use?? I thought about oversize pistons, but if I went to 81mm could I still use the 88-91 Teg pistons on LS rods?? Also, if Im going to have to get it sleeved, how big could I go?? (like litres)??? Any idea how much it would be to get it done?? Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Well what rods/pistons should I use?? I thought about oversize pistons, but if I went to 81mm could I still use the 88-91 Teg pistons on LS rods?? Also, if Im going to have to get it sleeved, how big could I go?? (like litres)??? Any idea how much it would be to get it done?? Thanks!</TD></TR></TABLE>
You can still use the LS rods but you would need to go to the B series pistons
With an 81mm bore, you get a 2.0L SOHC D series engine.
Cost = around $1,300 for sleeves, pistons, and rods. So, you could probably go with just the sleeves at about $800. and buy some B series pistons (take your pic) and another set of LS rods.
Thanks Spade!!! You truly are a D series dipstick!
EDIT: Has anyone ever seen a 2.0 D series??? Any idea of what kind of numbers Im looking at???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Thanks Spade!!! You truly are a D series dipstick!
EDIT: Has anyone ever seen a 2.0 D series??? Any idea of what kind of numbers Im looking at???</TD></TR></TABLE>
LoL Thanx.
2.0L D's with a custom cam put down 170 whp and 130 ft-lbs.
Stock cam and head, I'm assuming you loose about 20 whp.
LoL Thanx.
Haha! Hell yes!! Time for some serious D series powa!! hahah! Aww dangit,...now Im getting all excited...time to get up with the machine shop!!!
I am interested in how the teeny stock intake setup and head will flow for a 2 liter setup on a D block?
I have a spare CX block, maybe I could start a 2 liter project as well?
then make a mini-me setup thats not so mini !
good luck!
good luck!
Re: 2.0 D series (owen_the_soyboy)
just a little teaser.
78mm sleeve and bore....8.5:1 comp forged pistons, eagle rods and a Turbo.........(gotcha thinking don't I)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">Send the block the JG/Edlebrock or AEBS racing and have them sleeve and bore to 81mm.
Done.
You can't do **** without sleeving.</TD></TR></TABLE>
well.... u can get a longer stroke crank...
Done.
Re: 2.0 D series (allmtr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceNmotioN »</TD></TR><TR><TD CLASS="quote">Just curious on an idea I had. What do you guys think of welding a 10-20mm deck plate to the block to increase stroke. Think any possibilities of fitting a D17 crank too?</TD></TR></TABLE>
See signature.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr »</TD></TR><TR><TD CLASS="quote">
well.... u can get a longer stroke crank... </TD></TR></TABLE>
Try. I have and none of the manufactuers will respond. Kinda pisses me off.
See signature.
Try. I have and none of the manufactuers will respond. Kinda pisses me off.</TD></TR></TABLE>
really???? damn. thats suxl. hmmm.
really???? damn. thats suxl. hmmm.</TD></TR></TABLE>
Plus the stock stroke is already a little crazy.
Hell just think about it, your moving to the same bore as the B series engines (well most of them) and your pumping a larger displacement!!!
The D series stroke is quite large. (90mm)
a guy around here had his d16a sleeved to fit 81mm (b18) pistons and used machined LS rods. He put a home made ported y8 head on it (minime) and that motor is sick. Its like a 1.9 mini me. He said it dynoed at 169whp and it only had intake and full exhaust. Sounds like a fun setup to me
Re: 2.0 D series (Typesi2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv »</TD></TR><TR><TD CLASS="quote">a guy around here had his d16a sleeved to fit 81mm (b18) pistons and used machined LS rods. He put a home made ported y8 head on it (minime) and that motor is sick. Its like a 1.9 mini me. He said it dynoed at 169whp and it only had intake and full exhaust. Sounds like a fun setup to me </TD></TR></TABLE>
sounds pretty impressive to me
sorry to interupt the post... but OTT, but still related to d-series... does anyone know the gear ratios to a stock 95 cx? and also a stock 95 si? please let me know and then this post will return to normal.. but that 2.0 dseries sounds GReAT!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr »</TD></TR><TR><TD CLASS="quote">damn. 90mm! thats more than an ls. i had no idea</TD></TR></TABLE>
Yep. I believe the new d17 uses a 95mm stroke.
Re: 2.0 D series (HXMan)
http://dmoore.com/crx/tranny.htm http://home.cinci.rr.com/mistab0ne/tranny.html
booth sites have tranny gear ratioss
