1999 Civic Door Lock
Old 02-09-2009, 07:13 AM
110remington's Avatar
Default 1999 Civic Door Lock
I'm having a problem with the door lock on the front passenger door of a 4-door '99 Civic. The car locks and unlocks the other three doors properly. This door sounds as if it's unlocking, but the door won't open unless I pull up on the lock post and pull the door handle simultaneously. Either the inside or the outside handle will work.
I took the door panel off yesterday thinking that the issue was the actuator, but I really don't want to go through the trouble of taking the inside of the door apart if it's not a problem with the actuator.
Any thoughts or experiences?
Thanks
Old 02-09-2009, 09:13 AM
Former User's Avatar
Default Re: 1999 Civic Door Lock
Sounds like a bad actuator. You could test whether the actuator connector receives battery voltage when the switch is pushed. If so, replace the actuator. You might also as a test swap a good actuator from another door.
LT Link
11-05-2019 01:17 AM
m.glisson003
08-07-2011 12:36 PM
.one lane
11-22-2004 11:09 PM
KidMo
01-15-2003 12:06 PM
Quick Reply: 1999 Civic Door Lock
