1998 civic dx multiple codes
Old 09-06-2008, 03:47 PM
capscootie's Avatar
Default 1998 civic dx multiple codes
My daughter just took off to college and almost didn't make it. Car started running real rough and check engine light started blinking. I just pulled the codes p0171, p0301, p0302, p0300 & p0170. When I started it idled real rough but could get it to clear up for a short time by revving it for a minuite. It sounded like there was a snapping sound like a bad plug wire but couldn't find where it was coming from. I have recently replaced plugs, top O2 sensor, distributor and alternator and just had it pass an emissions test with no codes 2 weeks ago. Anyone have an idea what may have gone bad? The car is about an hour away and I'd like to make as few trip as possible to get this fixed.
Old 09-06-2008, 04:00 PM
Seagull Management
94EG8's Avatar
Default Re: 1998 civic dx multiple codes (capscootie)
Possibly a bad distributor, I know its new, but that still doesn't mean much, especially if it was remanufactured. You sure your getting code P0170? It doesn't show up in the honda specific list of codes I have, everything else does.
Hmm, upon doing a little more reading I'm starting to think possible fuel system problem may be the cause as well. Do you have a helms manual?
Modified by 94EG8 at 9:13 PM 9/6/2008
Old 09-06-2008, 04:38 PM
capscootie's Avatar
Default Re: 1998 civic dx multiple codes (94EG8)
I was leaning towards the distributor also and was thinking of putting back in the old one (replaced due to tps sensor code but ran fine) but the lean codes were confusing me also. I do need to replace the fuel filter and will do this 1st but kind of strange they came up at the same time. No manual yet but I see one in my future.
Old 09-06-2008, 04:47 PM
Seagull Management
94EG8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by capscootie &raquo;</TD></TR><TR><TD CLASS="quote"> I was leaning towards the distributor also and was thinking of putting back in the old one (replaced due to tps sensor code but ran fine)</TD></TR></TABLE>
TPS code? is that a typo? the TPS sensor is on the throttlebody. there are 3 sensors in the distributor, CKP, TDC, CYP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by capscootie &raquo;</TD></TR><TR><TD CLASS="quote">I do need to replace the fuel filter and will do this 1st but kind of strange they came up at the same time.</TD></TR></TABLE>
Well reading through the diagnostics the fuel system oddly shows up under each code, fuel filters are very often neglected, i've still got the original one on my '94 sedan with 313,000kms on it, it hasn't given me any trouble yet, should have been replaced years ago but i never think of it. Its easy to replace btw, conviently located on the firewall as opposed to the frame rail or in the tank on most other stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by capscootie &raquo;</TD></TR><TR><TD CLASS="quote">No manual yet but I see one in my future.</TD></TR></TABLE>
Best investment you will ever make as far as that car goes, unless you know civics inside and out trying to figure stuff out without a manual is just guessing and that only gets you so far.
Old 09-06-2008, 05:16 PM
capscootie's Avatar
Sorry cylinder position sensor (P1381). Thanks for the help I'm just looking to see if you guy's had anything else I might be missing before I drive back there. Any manuals that are better than others for the honda's?
Old 09-06-2008, 05:24 PM
Seagull Management
94EG8's Avatar
Helms seems to be perfered, next to the real manual from honda. chiltons and haynes are probably about the same.
Old 09-06-2008, 08:56 PM
H-T White Ops
NOFX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">Helms seems to be perfered, next to the real manual from honda. chiltons and haynes are probably about the same.</TD></TR></TABLE>
Helms is the manual from Honda.
Txdragon
04-17-2016 12:47 PM
Tchay
18
12-16-2013 08:21 AM
Integra2316
26
12-19-2012 07:46 PM
rfazio
02-13-2012 09:43 AM
jdmazm
04-24-2005 04:35 PM
Quick Reply: 1998 civic dx multiple codes
