1998 civic with d16z6 idle issues
Bought a car from this guy for $400 (automatic) but it idles up and down after idling for about 20 seconds and every now and then it will shut off. I've cleaned the iacv, replaced the tps (worked perfect for about 2 weeks then stopped), replaced z6 cam gear with a y7 gear, reset ecu, new map sensor. The only codes its bringing up is for knock sensor and high voltage map circuit.... could the high voltage be it? Bad ecu? Any ideas? Thanks
I never narc'd on nobody!
Re: 1998 civic with d16z6 idle issues
What's your point? Follow the diagnostic procedure I just handed you.
What you've been doing is called "wasting money throwing random parts at it." That's not what we do around here. We do proper diagnostics. It's cheaper, faster, and more effective than what you've been doing. If you'll do the proper diagnostic tests, we can have you fixed in a day or two. If you aren't, then please go waste someone else's time.
Fish Twig
The y8 manifold has nothing to do with your error messages. You know what the issue is since you notice the wires dangling there. Get to work.
The only wires really dangling are for the knock sensor. I'm not being lazy or anything. I just don't think it would effect it. My buddy doesn't even use knock sensors. But anyway I'm using a Y8 dizzy, could that have anything to do with it?
Fish Twig
high voltage map sensor circuit means the ecu is getting a higher reading than it usually should in normal conditions. Electrical issue. Did you reset the ecu?
Are you serious? It says, right in the page I linked you, exactly what tool you need.
At this point, you just need to go ahead and take your car to a professional shop to figure it out. We've given you two options. You decided to ignore both, and go for something that, diagnostically, there was nothing pointing to. Please stop wasting our time.
It's a unit of measurement for pressure, which is what the MAP sensor checks. If you pull up the MAP reading in a scan tool, it'll show you exactly what you need to see. If you don't have a scan tool, buy/borrow/rent one. If you can't afford to buy/borrow/rent one, find a friend who has one. If you can't find a friend who has one, find a friend who can buy/borrow/rent one.
And one last whack at the dead horse: Had you done proper diagnostics from the beginning instead of throwing random parts at it, you'd be able to afford to fix this.
