1997 ek hatch help with pr3 b16a swap
hi im new here , this is what i need help ....... 1997 ek with b16a i installed the motor already did the harness jump down to obd1 , here is the list of what ive done.
1. Eliminated ckp
2. Did iacv from 3 wires to 2 wires(99 ls iacv)
3. Extended all the wires needed to connect sensors
4. Ran vtec, oil preasure, knock sensor (og pr3 knk sensor)
5. I am ussing a 99 Ls dizzy with the leg removed, i will get o.g dizzy when i get more cash.
6. keeped d16y7 onjectors! Should i use 99 Ls injectors or am i ok?
7. Updated my throotle body to 99 Ls map sensor and tps.
8. I am running a p61 ecu with a chip on it im not sure what kind
Here is my issue guys if i missed any info please ask i will reply,
When i turn on the car the idle is up @ 2k after a while i get check engine and idle drops to
1.2K-1k when i test drove the car it sputters a little if i give it gas it takes a while to pick up,
I messed with the idle to try and fix the problem but my issue is if i missed any wires
I needed to jump or repin sotter.... can anyome give me a check off list i would really appreciate it.
Thank you in advance for taking your time to help me
1. Eliminated ckp
Technical Hero
Re: 1997 ek hatch help with pr3 b16a swap
-get the correct distributor
-get rid of the y7 injectors they are too low flow
-the correct ecu would be p30
-what codes does it throw?
-did you adjust the TPS?
the tps yes its adjusted .5v closed throttle and 4.5 -4.9v open
okay i will install the injectors tomorrow
with the chipped ecu the only code it would give me is 43
i put a s300 to mess with it and ofcourse it ran perfect but i cant buy that right now
im hunting down a p30 to see what it does
APZEE
14
01-13-2012 07:08 PM
E-Rok
09-17-2003 04:33 PM
