1993 honda civic ex problem help
ok well i recently purchase a 93 honda civic 93 it had a bad head gasket when i got the car the headgasket was trowing any smoke at all... welll i purchase a new headgasket and installed it but now the car doesnt stop trowing white smoke i did the headgasket twice n it still trowing massive white smoke any idead what it could be thanks
Re: 1993 honda civic ex problem help
theres a few things that could be causing this. you said you replaced the head gasket a few times, was the head milled? It sounds as thought the head may be warped and your head gasket isn't sealing correctly. If thats not the case then you have bad rings, you should do a compression test as well as a leak down test and see what you come up with. If you check the FAQ section I believe it shows how to do both and theres a compression calculator in there so you can see where your car should be at. If i'm not mistaken the compression number should be somewhere in the 190-200 range
well the funny part is that when i replace the hG itwasnt smoking as soon as i change it started to smoke like a motha ****kakakakakakak
som3on3_10
05-24-2006 09:14 AM
