14" wheel 4 piston brakes now available...
The 4 piston brakes for the 14" wheels are now in production. These will fit inside SOME 14" wheels, I've test fitted them to Panasports(minor caliper trimming required) and Del Sol aluminum rims. Preview price of $499.95 good until August 31. Kit comes standard with all mounting adapters, bolts, calipers and slotted OEM style rotors, all you need are pads.
Re: 14" wheel 4 piston brakes now available... (fastbrakes)
I am very interested in your products, I will send you an email of what I would like to do. I am curious about the pads used on the wilwood calipers. Are they wilwood design specifac that only can be purchased through you or online or is there a universal type of pad that I could get at a pepboys in case of emergency replacement? Any word if they will fit behind an hx wheel.
This is my dilema, I curently have the stock 9.5 brakes on my civic. I need new wheel bearings if I was going to upgrade to the wilwood system along with new balljoints and ss brake lines. So I don't know if this will be cost effective for me compared to getting gsr complet knuckles. Not only that I have to figure in the cost of new wheels and tires since I have the stock 13's on now.
[Modified by superflea, 11:46 AM 8/2/2001]
What type of caliper is it (Wilwood?) and what size rotor does the kit use? Is this kit for the 10.3" rotor cars or the 9.5" rotor cars? Thanks.
Re: 14" wheel 4 piston brakes now available... (bhcvc)
This kit is for the 9.5" brake cars. I use the Wilwood NDL billet calipers for this application...rotor is 10.2" x 21mm thick
93grayeg
03-04-2013 07:11 AM
Reelizmpro
09-22-2006 10:07 PM
fastbrakes
09-22-2001 02:05 PM
